93 SC300 HeadUnit Install Help
I've been installing a Pyle PLTSD7BT and oh my is the sc300 stereo confusing! It just won't turn on. Ive been using this diagram because its the only one that matches my stock system and its color coded as well: http://web.ukonline.co.uk/soarertt/i...diagram_03.jpg
I'm not sure about what to plug into the "ground". Right now its wrapped around a screw on a metal surface under the shifter. I figured my problem is probably with the memory battery or ACC wires.
Currently I have it wired like this ((not working)):
Yellow (battery anode +12v): +B plug
Red (12v ACC/Right+): Acc plug
Grey (Amplifier power control line): None
Black (ground): wrapped around metal screw
Blue (power antenna): P/Green and P/BLue wires
Pink (Braking line): None
I saw somewhere that someone had a 12v amp hooked in the memory battery place and that there is a wire for the braking line under the shifter. I don't know if not having the brake wire in could be keeping it from turning on. Could someone take a look at that diagram and tell me what I am doing wrong and what I should have hooked where? I just want it to turn on!
A HUGE thanks in advance
((sorry for making this so long. Just wanted to make sure I covered everything))
Heres the latest update:
I've got the stereo turning on (turns out i just had blown fuses) but the rear two speakers next to the sub aren't working. Is there a special way they have to be hooked up? I was playing with the fade and for some reason the door speakers played when i faded to rear and when i faded to front the tweeters were playing. Any ideas?
Also, How exactly do i get the factory sub integrated into my stereo?
and how can i be sure the amp is working?
the proper wiring diagram: http://web.ukonline.co.uk/soarertt/i...diagram_03.jpg
Kalogerus
01-01-12 01:30 PM
IIjzXXL
12-26-06 01:33 PM
Lvangundy
04-24-03 03:33 PM
