Here it is the wood panel I have been talking about!!!
This is the piece that I purchased from www.exoticwooddash.com
this is the radio piece blanked out...now all I have to do is measure up my radio and my DVD and cut out the holes....what do you guys think huh???
GREAT! Now do they have a "full" piece like that for the older GS, a 95-97 LS, and a 95 SC? Need some for a custom radio install...
Better yet, is there ANYPLACE that has matching Lexus PLASTICS? I'm not a big "let's turn our Lexus interiors in to an armoire" But matching wood looks a HELL OF LOT better than non-matching plastic!
Bad News?
Hey,
If you cut into that piece of wood you will cut through the lacquer that is on it and over time the lacquer will bubble because the wood will no longer be sealed from the air and moisture. You should have called them with your measurements and let them cut out your measurements for the wood and then seal it with the lacquer. (This is their regular process.) If you look at pieces that are already precut you will notice that even on the sides you can not touch wood. It is all sealed. Try it and see............I hope I am wrong.
Victor
Victor
Search Function Inc.
I can get the whole kit with a custom made part for your radio for around $200. The company that makes them is Russian so I can get a hookup...just need to find a guy I know there.
Hmmm, I would only need the console part. I dont' want all that other wood....I don't like interiors with too much wood...it starts to look kinda fake...
Although some of the older Lexus cars could use a few extra pieces (like the older GS's...but they just need it on the doors)
Re: Here it is the wood panel I have been talking about!!!
If you were to cut at an angle, you would see some of the inner material show through and would probably look horrible as well.
Depending on whether you feel 200 is too much to spend for customization of this piece (I think it is), the retrodrive method would probably look much much nicer.
BTW what are you doing with the rest of the kit you purchased...you have full wood interior already?
xsuperjoex----got two questions for you
1. Does the wood kit you purchased, match up pretty well to the factory wood???? If so, where did you get it from, can you give me a contact e-mail or phone number???
2. When you put your TV's in the headrest, i'm not sure if you swapped out the rear headrest to fit your TV's in there. That is what I did---so I have the rear headrests in the front seat and the front ones in the back. The problem that I am having is that I cannot keep the headrest up anymore. The stopper is different and because of the weight of the TV, after a couple bumps, it will start to fall. Do you know of a way to switch the headrest stoppers for the front a rear headrests???
Any opinions or suggestions will help alot.
2. Check your other thread I put something in there that might help you out a lot...because I did put the rear headrests upfront..
