SC speakers
Banned
Unscrew the front speaker piece from the back.
Take the front piece and draw its outline on mdf board.
Cut it out.
Dremel down the rear part, so that the new front wood piece will screw on. Cut out a hole for the speaker (you want the hole to be lower then the oem speaker).
Then put the wood piece onto the old plastic piece and screw them together. Dremel cut off the screws that appear on the back side of the plastic. This will allow the baffle to slide back into the car
Optionally, use some kind of filler wherever their is a gap between the old baffle and the new wooden side.
I did this and its not hard but does require some trail and error. Also when you mount the speaker into the mdf, you have to make sure the speakers wont hit the door panel. Thats why i say mount them lower then them oem speakers.
4" for the mids
What size are the tweets
and the sub is a 10" correct?
I have a bit more of an exacting question for you guys....is it possible to use the two signal leads going to the factory sub ( assuming i disconnect its small amp ) to hook a seperate larger amp up and power a new 10" sub?
Banned
http://www.intellexual.net/faq/lexusstereo.swf
this might help you and yes the sub woofer is 10 in. But i would NOT remount a subwoofer their unless you do somekind of setup with a really shallow box above the gas tank. Free air woofers suck and any high watt woofer will vibrate between it and the rear deck.
Also if you want to add your own amp and power a larger woofer yes its possible. I would get a line-out converter to turn the input signal into rca an aftermarket amp can use.
Not trying to thread jack but i didn't think it was worthy of a new thread..
anyone know any brands that make these 4" speakers? i was on crutchfield and it said that none of them fit?
I dont believe any 4" will fit perfectly, they will all take a little tinkering.
I've been looking, but all i see is the size that people upgraded there tweets too, does anyone know the factory tweet size?
No Sir, I Don't Like It
