Slight problem with JL Audio 500/1 amp, please help
Old 04-27-09, 09:28 AM
lexboi250
lexboi250's Avatar
Default Slight problem with JL Audio 500/1 amp, please help
I got my 500/1v2 amp installed on the weekend along with the 12w6v2 sub. Sounds great, however, there's a slight problem.
When I turn the volumn down and then leave it for a few seconds, then turn it back up again, there's no bass for about 5 seconds, and then, all of a sudden the bass kicks in. It's like a delay with the bass catching up to the song when I turn it up. But then it plays just fine, i wonder what would cause this issue. Anyone have any experience?
Thanks
Old 04-27-09, 10:04 AM
PK_Celsior
PK_Celsior's Avatar
still got warranty??? i would send it in. are you using a hi/lo input converter also? could be a problem there. if you could test the amp in someone else car it will help to diagnose between the two. you can also use a home receiver. plug your rca in there and see if it creates the same situation. if theres a problem with the amp. probably a lose transistor or something small.
Old 04-27-09, 12:38 PM
lexboi250
lexboi250's Avatar
i dont' think it has warranty, i bought it used from some one local. We heard it in his car before purchasing it and it sounded great. I have the LOC installed, so that should be ok. i'm not sure what's going on here.
Old 04-27-09, 07:34 PM
iron_lungs
iron_lungs's Avatar
make sure the remote wire (thin blue wire) is ran from the head unite to the amp. some install places just run the rca wires. if thats the case, go back to them and tell them you want the remote wire ran to the amp....and its your preference.
Old 04-27-09, 08:33 PM
mtparker18
mtparker18's Avatar
Either way the amp would still run, with or without a remote. JL has signal sensing.
O.P., what is your setup? that might help a little
Old 04-27-09, 08:37 PM
iron_lungs
iron_lungs's Avatar
you're correct, however the amp does not receive a signal unless the volume is turned up. i had this same problem, and the remote wire fixed everything.
Old 04-27-09, 08:44 PM
mtparker18
mtparker18's Avatar
really? I've never had that problem.
Old 04-27-09, 09:59 PM
lexboi250
lexboi250's Avatar
I have it connected to my factory non-ML nav unit, also got the bass control **** installed. I have a MTX RE-Q installed also (bass restoration unit, had it on my previous amp, no problems), with a single JL 12w6v2. A friend of mine mentioned that there might be a flat spot on the gain setting, and suggested me to turn up or down the gain to see if that helps, what do you guys think?
I'll check on the remote wire too to see, but i remembered my installer did install that, i saw it, maybe a loose connection?
Old 04-27-09, 10:00 PM
lexboi250
lexboi250's Avatar
ok, this is a bit more weird, when I start the car, even with the volumn turned to 30 or 40, no bass, leave the song playing for about close to a minute no bass, so i change a song, and wait for about 10 seconds, and now boom! bass kicks in..... :S i'm dumb founded. i have no idea what's happening here...
Old 04-27-09, 10:23 PM
iron_lungs
iron_lungs's Avatar
take it back to the installer so they can trouble shoot the problem
Old 04-28-09, 08:08 AM
lexboi250
lexboi250's Avatar
i'm gonna give JL a call first to see if they think it's an amp issue ( i hope it's not), and i'll call my installer.
Old 04-29-09, 05:32 AM
lexboi250
lexboi250's Avatar
okay, i figured it out. didn't have to call JL or anything.
There's a switch "Signal Sensing", it was turned ON, so I turned it OFF, and now, bass is always there and no delay.
Thanks everyone!
JB84
08-13-18 01:41 PM
skpark70
05-23-09 05:06 PM
airportis
08-22-05 07:22 AM
BigRich
01-25-02 10:27 AM
Quick Reply: Slight problem with JL Audio 500/1 amp, please help
