Entering Voicemail numbers into phonebook
I have a 2007 ES 350 and am having an impossible time to enter my voicemail password into the phonebook for speed dialing.
Any suggestions?
Any suggestions?
I'm not sure if this will work for you, but I was thinking about this..similar prob I had to programming a phone set up..(diff set up, but, hey, who knows..)I hope this helps, or at least might spark an idea that will.. try entering your VM #, then a "pause" (like a comma or two if you can) if it lets you.
Sometimes if you are able to enter a delay in your dial string, it's just enough time to enter your password.
I tried the pause and then a couple of pauses with no luck. Not sure if the issue is with Sprint or the car's system.
Thanks for your consideration, though.
ChipC
ES - 6th Gen (2013-2018)
15
01-06-14 01:55 PM
