Amp Getting Hot
I have a 2GS and I just recently installed my system. Only problem is that the amp seems to be getting really hot. It is screwed onto the back of my sub box and the sub is kept in the raised section. My friend says that if it gets too hot then the amp might blow out. Should I move the amp some where else? Id like to move it on top of the box, but my factory sub is still there and Id rather just leave it there. Where are you guys putting your amps?
What subs are you running? If they are wired incorrectly, you may be causing it to overheat. Also, if your power cable is not of sufficient size, could be the same problem. Let us know.
Big Mack
Big Mack
Big Mack
I asked a professional installer to look at it and he said that it was fine. Its supposed to get warm like scooter58 said. I just thought that it was hot. I touched my friends amp and its just as warm/hot as mine, so I think everythings ok. Thanks for your input guys!
OK NEW PROBLEM!!!!!!!!!!!!!!!!!!!!!!
Ive been leaving the sub out towards the front instead of the small compartment in the back. I just moved it to the back last night and today while I was driving, I noticed a really weird smell. Its like something was burning, but not that distinct burning smell. I really cant describe it, but I stopped and pulled the sub out towards the front and it stopped smelling as bad. I think the amp was burning the carpet on the back of my rear seats or something.
WHATS GOING ON??!
WHATS GOING ON??!
WHATS GOING ON??!
WHATS GOING ON??!
RoMiLex
08-13-14 09:15 PM
SC3005SPD1
12-04-07 09:20 AM
