HELP! Subwoofer fix possible?
Under the cone, there's a wavy stiff paper disc thing that should be flexible, but firmly attached to the speaker frame around the perimeter (from what I can tell).
In one area at the perimeter about 1.5" long, that paper disc is rattling. The rattling goes away when I put my finger there to hold it down.
Will simply gluing this back down somehow fix it?
Big Mack
I liked the hot glue cause it sets up really quick. 5 min expoxy takes 5 to set and several hours to cure completely.
Good luck, remember to close this out with your results, and if you can post a picture or 2 I'm sure there are some that would really appreciate it.
This worked 100%. I used epoxy. Hot glue got gooey and setup quick. I could scratch it back out with my fingernail. So I tried epoxy--it gets runny, so after it slid into where I put it, and hardened, its perfect. (Again, this is around the perimeter of the paper "spider" part of the speaker.)
viper.boy
07-25-08 09:00 AM
Hartawan
05-14-06 03:19 AM
