93 300 5spd's stereo hack...
933005sp's stereo hack...
I've got a copy of his stereo hack on my site -- for now it's http://209.125.175.29/scstereo.html
and
http://209.125.175.29/lexusstereo.html
enjoy.
PS: I will soon be getting an actual DNS name -- it'll be http://jtj.tocci.com (okay, okay, now everyone knows my first and last name!)
--John
and
enjoy.
--John
The sound system in the SC has about 20 color-combo coded wires running from the center console to the corner of the trunk in order to relay signal and power from the stereo receiver, to the amplifier, cd changer, and antenna. This means abolsutely nothing to you unless you are trying to install aftermarket stereo equipment into your SC and want to continue using the thick-gauged, shielded, preran factory wiring. It's also important if you just want to install a new receiver only, because the wiring harnesses vary from each car manufacturer and also with each audio manufacturer. For instance, when you're installing an Alpine deck into your SC, you need to know which wire is the antenna trigger, which wire is ground, which sends signal to the front right speaker, etc...times ~20. This hack diagram outlines all of that for you so you don't need to test each wire individually with a potentiometer.
oh, ok... thanks.. i got rid of the deck in my car and got a flip out screen, but the only thing i wish i could do is wire in the master control *** that came with the car in with the aftermarket reciever because its hard to find the volume control all the time on the screen... im a lazy ***... i had someone else put in the stereo stuff for me... like i said before, when i have more time in my life and im out of high school, ill learn how to do all this technical work and do it myself. i wish i knew how to do it though ;(
Where's the Nak Hack?
John- it sure was nice of you to host Peter's info, but as I recall, he had 3 separate files for the Standard, Premium and Nakamichi systems.
I can only find the first 2 on your web site. Is the Nak Hack (gotta nice ring to it, don't it?) stored elsewhere?
UPDATE: John added Nak Hack to:
http://209.125.175.29/main.htm
1997sc300
12
01-13-13 10:45 PM
DontHateSc
01-08-04 09:27 PM
SDSC300
04-28-02 10:49 PM
