Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#241
I have the same Pioneer unit ashtray is talking about. It is the amp wire and for whatever reason, there is no other wire for the antenna. My antenna stays up as long as the unit is on. I was going to make a switch to control it.
#243
Couldnt find the antenna wire. Now the antenna is just up all the time. Oh well.
edit: Followed everything step by step and worked out perfect. Now I just want to get the DVD working while driving and figure out the antenna wire.
#247
It is a Pioneer, but it does not have the navigation system. I figured I didnt need it as I have a Garmen. Just read online that I can ground the parking brake wire and get a toggle switch for "on" "off" grounding incase I get pulled over. Will this work with this unit...
Pioneer AVH-P3300BT???????
#248
#249
#255
Raine I got another sub bypass without using the stock sub amp, and use the aftermarket stereo.
From aftermarket sub output to the stereo harness is white=neg and black=pos
Clearly in on the first page.
From the subwoof it is white/black=neg and red/white =pos.
From the sub amp, cut white(G5), black(G1), black/white(G9), and red/white (G10).
Wire G5 with G9
G1 with G10
My question is, which output more power, the stock amp or aftermarket stereo (not amp).
Wire G5 with G9
G1 with G10
