Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#601
Wow I just read through this entire thread. So many mentions of someone figuring out the Nak setup with no follow through. This is a great write up, but I must say I am extremely disappointed to find out (after so much reading) that no one has gathered all the information to make the Nak system work. My 97' SC400 is apart in the driveway and I'd be happy to write it up with some help from a wiring expert. I've got photos of my wiring and connectors already. This is a long shot.
I'm not sure if Metra changed their harness since Raine's original writeup but it does work now except there is no illumination wire on the Metra harness. My car is still apart so I have not driven it yet but I hear no alternator whine (yet) while revving the engine. I ran 6 RCA's to the trunk already because I couldn't get the RR speaker to work and thought the Metra harness didn't work but it turned out that the speaker was dead-dead, so I guess I'll leave the RCAs for a future project.
**EDIT** A new Metra harness showed up today that was not modded during my attempt to find the bad speaker I mentioned above. I ordered it to confirm it was just a bad speaker. It turns out after using this new, unmodded, Metra harness that the FL(driver's) speaker did not work. I returned it to the modded Metra harness and all is good again. The only mod to the the harness was cutting the extra ground wire that went to each of the 4 RCA's and separating the grounds (bare strands) connecting the four RCAs (requires some removing of the sleeving on the Metra harness). See below photos.
Top - Cut ground and removed shared ground between 4 RCA's (not observable)
Bottom - Original Metra harness.
Background
Last edited by Strezzd; 11-28-20 at 07:10 PM. Reason: Correction to original post.
#602
The "Metra 70-8112 radio wiring harness for Toyota Amp Integration 15 Pin" (**edit** see below) worked with my Pioneer AVIC-8200NEX using the factory Nakamichi system setup. All four speakers worked as well as the subwoofer (powered by the single amp under 12 CD changer). I have a 1998 SC400.
Background
Background
#603
Head unit won't turn on unless amp is plugged in
Hey guys, running into a bit of an issue i'm having trouble solving. I hooked up my head unit as per the guide, bypassed the amp and everything else but for some reason the head unit won't actually power on unless the amplifier is plugged in, wondering if maybe the radio gets it's on signal from the amplifier being powered on? Makes no sense to me since everyone else had luck.
#604
This is exactly what I was looking for! My kids 92 SC is on its 2nd Pioneer and I just managed to install a Farenheit EFM-02 FM modulator to allow him to listen to his aux in phone music. I got him a double DIN Kenwood NAV/DVD/CD/SAT/HD whole enchilada and a Metra bracket. I dont even think I need the Metra bracket as it looks 95% like the stock metal one? Im not certain the sub amp even works, FM sounded like ****, but the CD sounds great? Could the FM not be turning on the sub? Im probably going to install an old 100Wx4 amp in the back and maybe a 200W bridged 2CH amp for the sub if its bad. All in the trunk where the CD was.
#605
I-1 clarification. I just did this and the '93 subwoofer grill is on REALLY tight. Pry up the corner to see the metal clip and put a very wide blade screwdriver between the grill and the clip base NOT THE FIBERBOARD, IT WILL BREAK! Turn screwdriver to pop it off. My 10" sub cone was gone. Only the coil cover was there! Is there any way to tie into the heave front speaker feeds from the radio area or do they run up the sides? Seems a shame to run 4 pairs back to use the factory 2 pairs up to the front again. I could not locate them in the harness behind the stereo.
#606
#607
FYI the factory amp under the changer is only 30Wx4 (2 Toshiba TA8221AH in parallel) so dont be afraid to bypass it with a higher power head unit. The Kenwoods typically have 50Wx4 out. Anyone know the Sub amp power or stock Sub (92 Pioneer 10") power rating?
#608
Ignition
I wired everything in awhile ago, and most of it is working great. Touch screen JVC head unit, universal wiring harness. My speakers work and the head unit works, but I have to turn it on and off every time I use it. The radio also drains my battery over time. I have the red wire from the radio connected to the grey wire in the car, and it doesn’t work. I’ve tried different wires and nothing seems to work. Anyone have any guesses?
supermj
18
06-24-13 04:58 PM
AZ-GS300
15
06-03-06 02:52 PM
marcman18
05-10-01 03:17 PM
