Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#61
1. Have no sound except for the subwoofer
2. Run seperate amps for the main speakers (which is not what this thread is about)
3. Run speaker wire from the head unit to all four main locations (both doors and rear deck)
The point of this how-to was to install an aftermarket head unit to work with factory speakers =)
#65
Hey guys, I have a 1993 Sc400 with the Naka system. I have the factory unit pulled and I know it is different than the Pioneer system, but I saw that Kponti had done the naka system. I am having trouble figuring out which wires are which. i found what i thought was the correct wiring diag online but it doesnt seen to be right. I tried going with the same wire colors (ie Blue with yellow stripe for power) but I am getting nothing. I also noticed that there is a separate harness that goes from the radio to a plastic piece under the radio. It looks like just an extender to me, but I tried to bypass that whole thing and I havent had any luck. Any help would be greatly appreciated. Thanks Again
#66
#68
nevermind okay got it the cable to jump the wire by the rear speakers its grey on G4 location on the socket side to g6 purple on plug side.
my car doesnt have the amp since first owner took off all the sound system setup so im running just the speakers (no sub yet) which sounds Good im glad it works. i just have to get a Amp now.
great write up it helped me very much thank you!!!!!!
#69
#71
After reading through all the posts, I think just use a 5 channel amp or two amps (your choice) with the head unit and get the best sound out of it. Run the RCA cable with the remote turn on wire back to the trunk. Then run the wires to the sub directly and wires to the speakers behind the factory amp. Up front, find your battery power, ACC wires for your red and yellow wires from the head unit. Ground the black wire to the frame using one of the mounting screw. Hook the RCA cable up and the remote wire for the amp, and the antena remote wire to the antena wire on the head unit. Plug the antena cable in and you're done.
For real, if you do all that work to get better sound and all, why do half the job? The extra money spent on the amp(s) will be worth it.
And while you at it, if you use a DVD/monitor head unit, ranging between $150-2000, depending on what you find, you can hook up back up camera, PS3, etc. to it. Head units with Navigation, bluetooth, ipod integration are now pretty cheap and can be found over ebay, amazone, craigslist, and such. With some patient and times, you can get a whole audio/video system going for less than $500. Just my 02 cents
#72
Originally Posted by raine
IS THIS THREAD FOR YOU?
For reference, this thread is for SC300/SC400 owners who wish to:
1. Replace their factory head unit with an aftermarket one.
2. DO use your factory speakers.
3. DO use your factory subwoofer.
4. Do NOT want to install a separate amp for the main speakers.
5. Do NOT install a separate amp for the subwoofer.
#74
Raine, first off i can't imagine how long it took to make this thread. thanks very much.
i'm in the same situation as you, i just installed my aftermarket head unit, but the stock nak sub is un-responsive. here was a suggestion from crutchfield, but if its total bogus don't get mad or anything cause i'll admit i really need to know more about electronics and such. but, there are 4 clips to plug into the back of the stock HU...now, crutch says that in one of those harnesses, farthest to the passenger side, there will be 1 blck/ 1white wire. those will power the sub and what not. so supposing we splice those to the harness my aftermarket HU came with, is it possible that would work?
at this point if that has zero chance of working then i'm probably going to grab a new amp and have it installed somewhere just to avoid the hassle and uncomfort it would bring me lol
once again thanks a lot for this thread bro i followed it as much as i could/knew how to
#75
Hmmm... I suppose that if you have the signal portion going from your new head unit to the sub amp, and Crutchfield is right about the Nak wiring (I honestly don't know anything about it lol) then giving power/ground to those two wires should give your sub sound.
