Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#93
oh bro - it was TOTALLY worth it! You're helping out countless other's who might never actually come in here and comment as well. It's an extremely valuable resource for SC owners
#95
NO! NO! NO!!!! You're doing it ALL WRONG!??! D1 plug is for your blinker fluid and D15 is for your muffler bearings! With this kind of re-wiring, you can easily burn out your horn motor.
J/k
Thank you for doing this great write up. That was one reason why I kept my stock head unit for so long....
I do have few dumb questions for Killa-Hz. (please don't laugh at me.)
Eclipse plug? I am assuming mitsubishi Eclipse, but what year?
I kept looking at the picture and kept reading your post. I just can't figure out if I were to purchase a plug/s for a mit eclipse, will I get 2 females or 1 male and 1 female? The plugs look like they will fit the "D" plug from our SC, but what about the "A" plug?
Sorry for asking stupid question.
J/k
#96
Got mine partially wired up but Still no Sub.
I don't understand this:
Only 1 single Cable (RCA to speaker wire) connecting from the Factory wiring (blk & white wire) to the Sub Out??Shouldn't there be 2 like normal?
I don't get it.
I don't get it.
#99
anyone get the nak wired correctly i used his great example but where you connect g4 to g6 i cant find that plug in our car so i have no bass unless on fm am so im stuck untill i find that plug
#100
"Fifth, the nakamichi amp 5 channel amp(1st and 2nd NOT 3rd gen models) is basically the 2 pioneer amps rolled up into one. In fact it even uses the same 3 plugs as the pioneer system. The only difference being some of the subwoofer plug pins are missing; more importantly the subwoofer inputs are missing. What this means is the amp calculates the outputs to the woofer based off the 4 speaker inputs. This IS TESTED and CONFIRMED."
https://www.clublexus.com/forums/4653536-post1.html
I figured it was pretty much hopeless since the amp is supposed to calculate the subwoofer output based using the 4 speaker inputs. I ended up just using an aftermarket amp and subwoofer... which actually sounds great but I was a little frustrated that I couldn't get the stock Nakamichi working.
#102
You were able to get the Nakamichi working on FM? I thought I tried pretty much everything I could think of and couldn't get it working even on FM. I found a post stating that:
#103
Am I blind or does my unit not have a dimmer wire?
http://www.dualav.com/support/manuals/xhd6425.pdf
#104
Well I did this today and got everything working except my antenna wont go up, I can tell its working because when I pull the wires apart I lose reception but when they are crimped no power to raise the antenna, any thoughts?
#105
Okay got everything installed, thanks for the writeup. My antenna goes down when I turn the car off but not switch from radio to aux, cd etc but thats no biggy. I still need to pull out the metra kit and make some room in the back because the left side of my dash molding is sticking out about 2 cm's for some reason.
