Percy or Mean Gene or anyone with a service manual
Can someone with a paint brush program and a service manual filled out the wire color and the pins label for all the pins on the ECU connector?
I am building a true wide band 02 sensor circuit and RPM monitor w shiftlight. (will do a write up when I get everything build). But I need to know which wires are comming into the ECU. GS400 only (maybe the 300 is the same)
I am especially interested in O2 (primary and secondary wires), gear shift (if exist)
I am planning to spend sometime with the lexus ECU, if I can get a detail pin descriptions for the ECU for the GS3/400. That would help alot. I am pretty sure there is a page in the service manual that shows the brief description of all the connections to the ECU.
Thanks.
Anh
Thanks.
Anh
