programming a key for 2006 Lexus
I just bought a 2006 GX470 (great deal, etc.).
The car came with one key.
The got the dealer to give me a the chip for a second key. So I bought a shell from the dealer (so the key cutting would be exact). The dealer told me the remote battery is good.
Now, I need to program the new key.
I've found 2 different methods of programming the key (one on this site- turn ignition on/off 5x open driver door 6x, etc.). The second method said press gas pedal 5x, break pedal 6x, etc.
Then, both methods have a second piece of info called "remote programing" (both of which are different).
So, questions:
1 - I belive I need to program the key in the ignition first. Then I follow the remote programming to program the key to lock/unlock the doors, correct?
2 - Both methods of programming the key in the ignition did NOT work. I tried both methods multiple times. (I'm doing the steps quickly so i'm sure I'm under the time limit).
Am I using the correct set of instructions?
Thanks.
So, questions:
Thanks.
any help?
I've been able to program the new key to open and close the door locks but can't program the key to turn on the ignition.
I've done a bunch of internet searches and have read as much as I could find in this website but I still can't get a straight answer.
Can I program an ignition key for a 2006 GX470 or am I screwed and need to go to the dealer?
Thanks.
rcoyne
2006 GX470
Thanks.
rcoyne
2006 GX470
drich2905
07-26-13 01:51 PM
