marine 10" JL infinite baffle sub replacement ..
i was wondering if this would work for the stock sub location? http://cgi.ebay.com/NEW-JL-AUDIO-M10...d=p3286.c0.m14
i tried searching for 10 inch infinite baffle to replace the stock sub.. all i can come up with were marine subs that are 10's .. i found some that were 12's but that wouldnt fit the stock location.. any suggestions?
Zombie Slayer
Yep. Will work just fine. Just be aware that while the rated RMS wattage on the driver is 250, when in an IB setup power handling is greatly reduced. Try not to run any more than 150-200 watts RMS to the sub.
