Help wiring Subs to amp
I suck at audio stuff. I need your guys' help wiring up my subs to my amp.
Subs: 2 JL 12w6 V2's. DVC 4 ohms.
Amp: Hifonics Brutus BXi1210D
I'm going to be wiring the subs together as per this diagram to get a final load of 1 ohm
![](http://www.rockfordfosgate.com/rftech/woofer_wizard/2_4ohmDVC_1ohm.gif)
Now, on the amp, there's 4 subwoofer terminals. My question is, in the subwoofer diagram above, it shows that in the end you'll have 1 Positive and 1 Negative lead after you wire up the subs together for 1 ohm, so do I use only 2 terminals on the amp (like in the picture with 1 subwoofer below)? Or do I use all 4?
Here's the layout of the Amp
![](http://i44.photobucket.com/albums/f46/thebeeguy/Amp1.jpg)
wire it in mono aka bridging the speaker wires. ur going to wire up 1 positive and 1 negative only. the 4 terminals are for 2 subs. if ur wiring it in 1ohm then u just wire ur one positive to the positive for 1 channel and ur negative to the other channel like in the pic
CLRH2O
01-31-10 07:31 PM
2Fast0
04-28-06 09:26 PM
joshoowa
10-04-05 10:19 AM
