DIY Alarm Issue
Old 10-05-09 | 06:30 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Default DIY Alarm Issue
I have searched and searched and cant find my answer and a DIY anywhere. I want to be able to hear the horn, or lights flash, or the cornering lights and tailights to flash, or a combination of, when you arm and disarm your FACTORY alarm with key. Lastly, I also wanted to add a lit interior when diarmed as well. Does anyone know how to do this or can someone post a link?
Again, I have searched and found nothing, just some people saying use relays, but nothing further. Thank you! I have 1992 SC400, if that matters.
Old 10-06-09 | 11:50 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Its not a simple DIY project. You will need some basic to advanced electronics knowledge.
You will need to build a relay circuit off the lock and unlock wires to trigger the flashing lights/horn honk. Additionally, in order to make the lights flash a flasher will need to be wired in series to the light output. Also, a timed output module may be needed as well although I'm not certain on that. I would need to draw the circuits out and think about it a bit.
This link may help you see how the circuits would be designed. The input feed for these circuits is a lead from an aftermarket alarm (siren output/lock output/etc). You should be able to use your lock and unlock wires as the input lead (trigger wire).
My advice though is to locate a local shop that is good with custom wiring and circuitry and have them tackle this for you.
Here's the link:
http://www.dlcparts.com/images/BoschGuide.pdf
Old 10-07-09 | 07:48 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I appreciate the link. It helped me understand the wiring thing a lot better. If you think you can draw me up a digram or something, please PM me. Thanks for your any help on this. This is more than what I have found!
rcJten
02-08-15 10:03 AM
JoshIS408
01-08-10 08:58 PM
raine
05-28-09 02:27 PM
Quick Reply: DIY Alarm Issue
