help need info on installin a hidden antenna
Old 10-07-09 | 04:06 PM
Lexscme's Avatar
Lexscme
Default help need info on installin a hidden antenna
So i got a hidden antenna from the junkyard today and im tryin to figure out how to get it working, i splice into the grey wire for ACC 12V and grounded it but couldnt find a decent grounding point.
I followed the wire diagram on how to install a aftermarket stereo with stock amp... after wiring up everything still no sound yet??
ooh and it was a 5 finger discount when i got the antenna.
i got pics of it but i dunno wheres a good ground?
Attached Thumbnails help need info on installin a hidden antenna-img00208.jpg   help need info on installin a hidden antenna-img00210.jpg   help need info on installin a hidden antenna-img00209.jpg
Old 10-07-09 | 09:57 PM
Lexscme's Avatar
Lexscme
anyone? ive searched no clue
Old 10-09-09 | 09:15 PM
Lexscme's Avatar
Lexscme
no one knows how to install it?
Old 10-09-09 | 09:32 PM
masagsxr's Avatar
masagsxr
Good grounding point would be to the chassis. Looks like you tried to screw it in between two plastic pieces? .... You could always extend the wire if you need to and create a grounding point to the chassis by drilling a small hole and use a coarse type screw. Another would be tapping it to the ground of the stereo harness.
5 finger discount... LoL...
Old 10-10-09 | 08:32 PM
Lexscme's Avatar
Lexscme
YUP!! my buddy was takin out a alarm from a prelude at the yard and i saw the antenna im like i need that! so i just stuck it in my pocket and walked out.
Kool ill just tap into the stereo ground and see if i hear anything? thanks.
Sean628
07-29-17 01:04 AM
joe diego
Performance & Maintenance
05-03-15 01:38 PM
Shiryo
07-21-13 04:40 PM
shajbot
11-15-08 01:28 PM
1loudlex
12
04-28-03 07:43 PM
Quick Reply: help need info on installin a hidden antenna
