Speaker Gurus...
Sound deadening - what you plan on doing in the trunk to make it quieter from road noise.
You can use components, you just have to sum the signal back together with the unit you asked about (Cleansweep) or something similar, such as the RF 360 or the Audio Control LC6 or LC8 before the amp so that it sends the whole thing to them, and their crossover splits it back up.
Big Mack
Big Mack
If it's installed correctly and you tap the lines properly, it should make the sound very good. Certainly not as good as a complete aftermarket system that isn't split, amplified, summed, split, and amplified again, but I digress...
Big Mack
