500W or 1000W Amp with JL Audio 12W6v2 Sub
Is it worth the extra money to get a 1000 watt amp to run JL Audio's 12W6v2 subwoofer? The power chart says 500W is in the orange/red "danger zone" but peak power is at 1200W (warranty void past 600W). Will I be missing out on much if I only get a 500W amp? Is it bad to be running the 500W amp at full power all the time?
PS: In case it wasn't obvious, I'm an audion00b.
Moderator - Electronics Forum
I'd be very surprised if you could run 500 watts at the subwoofer ALL the time. The power for the sub is mostly used in peaks or transients. The most critical part is the midrange, where we hear 90% of the real music.
The difference between 500 and 1000 watts isn't that much. Since our ears are logarithmic in nature, you would need 5000 watts to sound TWICE as loud as 500! 50 watts would only sound 1/2 as loud as 500.
Stick with the 500. It'll be plenty unless you're out to burst your eardrums. Your alternator will thank you too.
And no, you really don't need an outboard capacitor. I'd actually recommend against it.
olddog
22
04-24-07 03:53 PM
JsN
10-26-04 03:19 PM
Kevin
06-07-01 11:41 AM
