HELP! double din has no volume. is300
I bought the premium harness for the is300 and everything is plugged in double din turns on but there is no volume! Anybody knows what the problem is?
Which harness did you use, the Metra TYT0-01?
Did you connect the blue/white amp turn-on the harness to the amp turn-on wire from the head unit? If not, that could be your issue. If the factory amp isn't turning on you won't get any sound.
Also, with the exception of the head unit is the rest of the audio system still stock?
A bit more info may help with finding a solution.
YEAH! i used the TYTO-01 metra yeah everything else is stock my sub works though with my aftermarket amp, and yeah ive been hearing about that factory amp, and i connected the blue wire remote on the double din to the blue wire of the harness
