Attn: Anyone with Mark Levinson & aftermarket bass
I have an 06 gs430 with ML. I have asked before and searched 100 times. The only thing I see is people without mark levinson that think they know what they are talking about, or people with mark levinson and no aftermarket bass that think they know what they are talking about...
I want aftermarket bass. I tried to use an output line converter. twice. and they both fried. The power coming FROM the mark levinson amp to the output line converter is too much. I need to find a way to either tap into the bass signal BEFORE the ML amp, or some other option I don't know about.
If you have ML & aftermarket subs, please let me know how you did this.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
/sarcasm. In all seriousness, that unit should work just fine. Soundgate makes quality products, and I've used them for years.
Big Mack
Yo dude. Thanks for posting. I think last time I asked about this you were the only one to chime in with input. So again, I appreciate it.
I have no idea what I'm doing wrong I guess. I have installed and uninstalled a lot of subs in my time. even ones with stock subs and stock amps (bose set up on my acura Tl). But I tried twice with my GS and can't get anyhting to work.
I took my car to a very reputable shop here in south florida when I fried my second LOC and the master installer there was in shock. He said I did everything EXACTLY how he would have. I told him I wanted to save the $ and do the instal myself but at this point I was lost and asked what he would charge to take care of it and he basically said he couldn't do it.
I was using an SNI-35 (per someone on CL.com's recommendation) but I have just purchased the unit you recomended in that other thread.
Thanks again!!
Thanks again!
Thanks again!!
Thanks again!
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Compatible with 2 - 40 watts RMS of Radio Output
This would be the problem. You overloaded it like nobody's business.
You're welcome again (x2).
Big Mack
Guys I have pulled this off in my car flawlessly. I am running an American Bass 900 watt amp and have a line out convertor and I am running 2 JLW3's 12". So far I have had no problems what so ever, also I do have ML
Will this be fine: : 2 Channel, 50 Watt per channel , Line Output Converter that will perfectly interface any OEM automotive system to an aftermarket power amplifier, equalizer, electronic crossover, etc. The N-RHL2 uses our "Industry Leading" NE-7V LOC circuitry, and adds the benefits of our N-902 Auto-Trigger circuitry� all in one convenient package. The PINK wire from the N-RHL2 connects to the Remote / Trigger wire of your aftermarket power amplifier so that it will turn on and turn off with the audio system. Let's say that you wanted to add bass to a factory system. Just tap into the car's factory speaker wires with the N-RHL2, and let the PINK wire control your sub woofer's power amplifier. Instructions included.
50watts vs 85watts from soundgate ? Now that i understand better, i can get away with 50watts since this nice unit has a remote trigger wire that will be very useful.
thank you.
thank you.
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
The ML amp pushes about 80 watts. I wouldn't risk it to save a few bucks. Yes, it is convenient to have the converter turn on the amp, but not at the risk of a vehicle fire.
On a side note, does anyone know what this little symbol is? I see it on the page, and I've seen it a few times here. It's rather annoying, as I know my browser and plug ins are up to date. Perhaps it's a character that isn't supported?
Big Mack
Big Mack
thank you Mack, i will go with soundgate then, found a good deal on Ebay. If i may ask Mack, do you work in an audio shop or something considering your knowledge.
As per the symbol : http://www.davidnavone.com/cart.asp?24&cat=7 ... it is the copyright
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Big Mack
Yep. OR, Audio Control Epicenter Plus
http://www.audiocontrol.com/t34/5249...Processor.html
Big Mack
305Busa
05-06-13 07:30 PM
Ty419
03-05-12 06:57 AM
KevinGS
09-04-05 12:47 PM
