Running Power Cable
Here's a thread the discusses that....
It deals with the SC, but it is very informative and many of the procedures covered will pertain to your car. Especially check out duB's web page (link in the thread)- he photographed the wire run:
https://www.clublexus.com/forums/sho...threadid=34734
Hmm...why recommend other threads when you can see MINE?
Actually, I just started another thread on the SC forum, where I posted several pics of my SC power cable install- maybe you'll get some ideas from that one, too:
https://www.clublexus.com/forums/sho...threadid=49351
Search Function Inc.
I havent put up pics yet but here is the best way I found to do it in my LS.
http://www.cureline.net/lex/audio/ho...ng_install.htm
Good info, Pete!
I was thinking of putting the fuse about 6" down the line from where it taps into the positive connector, but you say 18". I've heard that if you get too close, you risk getting that white "foamy"corrosion of the fuse area similar to what is seen on some positive post connectors, but I've never seen that happen in actual practice.
Any other reasons for your 18" preference?
Here's another option and what I did with my ES. You can run it underneath the car, in a sturdy conduit held to the frame rail with brackets; then going into the bottom of the trunk wherever you choose. This took about $20 worth of conduit, brackets, and a piece to go into the trunk from Home Depot. I preferred this idea to finding or drilling a hole to get 1/0 gauge through the firewall and trying to hide it under the carpet.
I've got to take some pictures and get my Sounddomain page going, it's easier to look at the pics than explain the exact things I used.
gilrebel
NX - 1st Gen (2015-2021)
03-05-17 01:36 PM
