RCA signal noise? ran opposite 12v+
I ran the RCA cables along the driver side of my 2002gs300 and the power cable along the passenger side but I still hear the "whine" noise produced from RCA signal distortion..
Along with the RCAs, I ran the GPS antenna wire, the reverse cam signal wire, and amp turn on wire.. could these things be affecting the RCA signal?
Where could I be picking up the noise from?
Is there a better way to route the RCAs? Down the center console?
Neme,
Check the entire path of the RCAs to ensure that they are not crossing any motors or other high draw items in the system. It is entirely possible to run power and RCA cables down the same side and wrapped together and not get noise in a system provided you are using a quality set of twisted pair RCAs.
My first suggestion is not to change the ground but to check and see if the noise is present in the amp without signal. Remove the RCAs from it, and if you still have noise, it's the amp. If not, it's upstream. Unplug them from the deck. If the noise floor is lowered significantly, it could be creeping in the cables. If it disappears entirely, you may have a problem with the ground on the deck.
Keep us posted.
Big Mack
Keep us posted.
Big Mack
The majority of the feedback is coming from the subwoofer only.. not any of the door speakers.
I can pretty much gaurantee that my RCA's are not that great of quality. I think I'm using the soundquest 8ga install kit?
http://www.amazon.com/SoundQuest-SQK.../dp/B001F6ITRE
How will I know if they're crossing any motors or high draw items? I just ran them along the door sills into the trunk. They do go up and across just under the steering column to the back of the HU though.
I'll unplug the RCAs and see if it still makes noise though.
So I unplugged the RCAs and I can still hear the distortion whine.
It is really really faint with the RCA's disconnected but it is about 3 times as loud with the RCA's plugged in.
Does that mean the ground wire to the HU isn't as good as it should be? I used the ground wire from the factory harness...
Those RCAs should be okay, since they're twisted pair. I don't like the idea of "copper clad," but they should be okay for this task.
Big Mack
It really sounds like a ground loop to me, although it's likely that a small amount of that noise is coming from the turn-on wire/GPS antenna as well. I wouldn't move those as a first solution though.
A good quick test is to take a few small pieces of wire and ground them to the RCA shields (do the channels concurrently). If that eliminates most of the noise, you can either use this rig system permanently or actually install a ground loop isolator.
Big Mack
Hey Big Mack,
So I unplugged the RCAs from the HU and left them in the amp and the noise is still there and still as loud (with some crackling even).
I'm guessing this means that I have to re-route my RCA cables, right? Can you recommend where to route them to have the cleanest signal? Down the center console? (2GS)
I then unplugged the RCA's from the amp too and could still faintly hear the whine.. Is there a way to tell if thats because of the poor ground on the HU or if its just a noise that the car is making? (besides obviously giving it a better ground)
Appreciate the help.
Evan
Evan
Hey Big Mack,
The HU has nothing to do with the amp having whine if it's not connected to the amp.
Glad to help, mang.
Big Mack
I grounded the amp to a pre-existing ground location behind the seats. Thats not good enough for the amp? And It could still be coming from the amp without the RCA's connected? I thought that it meant it was the HU acting up?
And I thought rule #1 of audio install was to route RCAs completely seperate from the Power cable?
PS. I have a LEGIT amp.. Precision Power baby..
How would the head unit be sending a defective signal to the amp if it's not connected. Amps don't read signal off the remote lead, only the RCAs. If they are not connected, the amp is simply amplifying whatever is present in the signal chain between the inputs and amplifier stage.
Old skool PPI, or newer post-DEI? They are VASTLY different animals.
Big Mack
old school.
what I mean is that I disconnected the amp 100%.. Removed the rcas and the power connectors and I can still hear the whine. That shouldn't be the amp should it? Maybe it's just the car and I'm going crazy..
I tested it without the car on and got a strong 12.89v but I'll double check with the engine turned over.
Nice.
If the amp is completely disconnected, it shouldn't be radiating any noise into the sub. Not sure what is going on there. I'll go with your diagnosis of going crazy.
Yes, check that. It should be almost identical if it's a solid ground.
Big Mack
Big Mack
