Installing JL W6v2 subwoofer and JL 500/1 amp
Hey guys,
I'm going to get a JL W6v2 and JL 500/1 amp installed in my 2006 Lexus GS300 and I have a quick question regarding the mounting of the subwoofer box. I want to bolt the box down to the trunk using mounting brackets, however, I don't want to screw it into the floor or metal. I'm thinking of mounting the box to a MDF board covered with carpet or vinyl to make it look clean...has anyone done this before? I don't want to permanently make holes in the floor of my trunk or in the metal. Any other suggestions on how to bolt the box down without making permanent holes in the trunk? Appreciate any feedback...sorry for the long message lol.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Big Mack
He said he's going to mount it to a beauty board. Very common, and totally doable. If you cut the board as wide as the space between the wheel wells, it won't be able to slide back and forth. I would strongly recommend that you counterbore and bolt through the beauty board into the box, securing it with nuts inside the box. This will make it much more difficult to remove, but not impossible. Simply install the sub afterward. I would also recommend putting some rubber matting (like that used in a tool box for the drawers) on the bottom of the combined box/beauty board so that it cannot slide forward/backward. You don't want a projectile in the event of an accident.
Big Mack
Big Mack
Sheehan1p
10-01-14 01:46 PM
D-MAN63
05-24-03 02:55 PM
