Adding subs and amp 94 sc400 nakamichi HELP
If i plan to adds subs and an amp which wiring harness will work for a 94 sc400 with a nakamichi factory radio.
The scosche ta02b or ta02rb or ta02r
or the metra harness?
Thanks alot
Thanks alot
Zombie Slayer
Are you keeping the factory head unit? If so, no harness is needed. You will need to locate the low level signal leads at the harness in the trunk. Splice RCA's into those to run to the amp then locate the speaker level leads in the trunk as well and connect the amp outputs to those.
