Headunit won't turn on?
so i installed an aftermarket headunit wired everything correctly with a scosche ta02b wiring harness and it wont turn on.
my battery died but i got it jumped and it was running but the headunit wouldnt turn on. could it be because of my ****ty walmart battery or possibly using a 30amp fuse in the 20amp radio slot?
please help
please help
The harness is the adapter.
Did you ensure the unit worked prior to installing it? You should always bench test a deck before going to all the work of putting it in just to be disappointed. I would suggest running a jumper right from the battery to see if it works first, then proceed to troubleshooting.
You do have a multimeter, right?
Big Mack
Big Mack
csum7913
RX - 1st Gen (1999-2003)
06-20-17 02:50 PM
PlacidBoi
08-12-12 06:59 PM
mk4r34
Performance & Maintenance
09-16-09 09:29 AM
suprang
12
05-13-04 11:17 AM
