Big 3 on an 01 LS430 help!
The big 3 should be the big 2 at this point - when the amp was installed, you or your installer should have upgraded the factory ground from the battery to the frame to equivalent sized wire to the power cable going from the +12V side. Was this not done? If not, that's step one. Should be pretty easy to locate and do in about 20 minutes.
For the other 2, you simply follow the factory path. It's likely the least restrictive and least difficult, therefore easiest for you to replicate. Also, if you use the factory wire to "lead" the aftermarket wire, it will do most of the work for you. Just be sure to watch any heat sources when doing so.
Big Mack
Big Mack
