Question: which set-up would you prefer?
I am thinking about a new audio install and wanted any feedback or advice I could get. Your thoughts and input would be much appreciated. I have a couple questions as well.
Option 1:
SRQ Custom dual 12" sub SEALED BOX
http://srqcustoms.3dcartstores.com/L...al_p_139.html#
with 2 12" Rockford Fosgate P2 @ 4 ohms, handle around 250 RMS
http://www.rockfordfosgate.com/produ...n_US&p_status=
powered by
Pioneer GM-D7500 400RMS @ 4 ohms
http://www.pioneerelectronics.com/PU...ries/GM-D7500M
The site says the box is "2.0 cu.ft of airspace for dual 12"," the subs are recommended to be sealed ideally around 1.02 cu ft, (Note, they displace about .057 cu ft each so that's .114 cu ft displacement total for both subs leaving 1.886 cu ft in the box). The max recommended by RF is 1.8, I don't imagine this to be a problem but if you think so let me know please.
Also, the amp runs 400 RMS @ 4ohms, so running to 2 subs does that mean 200 RMS each? (they handle 250) or is that truly 400 RMS total-to both subs? If so, that maybe too much.
Option 2
Rockford Fosgate 2 10" P2's in a ported box
handling 500 RMS @ 4ohms
powered by
Kenwood KAC-9105D
500 RMS @ 4 ohms
http://www.kenwoodusa.com/Car_Entert...iers/KAC-9105D
Leaves out any guesswork, but not custom looking.
This invokes the debate of ported v. sealed box. I want to be able to make my ears ring when I feel like it. My current set up does not do so (10" inch Free Air JL sub in stock cut out with older Fosgate 250a2 amp). Just FYI, I would use the cut out of the stock sub to "port" into the main cabin form the trunk. So, even tough ported enclosures are said to be louder, I think with 2 12's "ported" into the main cabin via the sock sub cutout would be equally as loud.
Your thoughts?
(P.S.-I have a pioneer HU (AVH-P4200DVD, 7inch touch screen)).
Option 1:
powered by
Option 2
powered by
Kenwood KAC-9105D
500 RMS @ 4 ohms
Your thoughts?
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
The Pioneer amp you pointed out has a typo on the main page. It's 200 watts @ 4 ohms, and 400 watts @ 2 ohms. Since that box is set up to run mono, you could wire both 12's together to 2 ohms. It's not really "custom" made to the speakers, but it should be fine.
That would be the setup I would go with.
Big Mack
Big Mack
Thanks, mang. I try. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
1 ohm is difficult for most amps to pull off. Despite the Kenwood saying that it will, it's a hard life for an amp. Also keep in mind that you'll be delivering 450 watts to each sub since it says it does 900 watts at 1 ohm (this is based on you using the 2 ohm RF subs). That's significantly overpowering them, and I wouldn't recommend it. I would either A) stick with the original plan, or B) stick with the original plan. Which amp is more cost effective? The Pioneer does 400 @ 2 ohms. The Kenwood should do 450 @ 2 ohms. If the price difference is more than 10%, that makes the choice pretty easy.
And I'm sure that stepping up from 1 10" sub in a free air environment off 250 watts to 2 12" subs with that much power to each will yield quite a change. It may not be ear splitting, but it should be plenty loud.
Big Mack
Big Mack
hmm.... a couple of questions I'd like to know.
1. What car is this going into?
2. Is your trunk "sealed" in a way that it allows the sound to fire into the cabin and not be lost in other "holes" that lead to other places?
If boom is what you're after, then I'd recommend a ported box, but a properly setup sealed enclosure would have more accurate and tighter bass IMO.
Vented may be more efficient - provided you don't go below the tuning frequency and unload the woofers, thus creating the big boom. 'Spensive! I agree with you that it can be louder, but building a vented box does require a lot more work than a sealed one.
Big Mack
Thanks for answering Big Mack!
I think I'm gonna go with the sealed enclosure. It is a 2d gen GS. From what I've read, ported enclosures are "boomier" but sealed enclosures are louder across a greater range of frequencies. Ported enclosures are real good at hitting higher decibels at certain frequencies but a good sealed enclosure will sound louder and tighter across the board. I can't imagine 2 12's with 600 RMS, "ported" into the main cabin via the stock sub cutout, will not be loud enough for me. Sure a ported enclosure might allow for higher decibels at certain frequencies but that requires I take up most of my trunk for an enclosure large enough. This sealed enclosure only takes up about a 1/4 of trunk space.
Thought I'd share some DIY pics. I could go louder but I like trunk space so I guess this will have to do. Overall, I'm pleased!
oh and the amp is the 1200 watt 8500 model so it's 600 RMS at 2 ohms.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Looks great, mang! Hopefully you are digging the sound for a long time.
Just out of curiosity, how much was the bang to ship the box to you? For a note, it's almost not worth it to do custom!
Big Mack
Big Mack
$135 total ($35 for shipping) and about a week later. It was the best option for me. I don't have the tools to build custom - nor the experience - and they can make any alterations you request.
Also, I appreciated that they used a thin layer of fiberglass resin to really seal it.
Here's a pic of the HU. there is some fitment and obvious material matching issues with the generic double din kit but just ordered the JDM double din from Carson (L-tuned) so that should be fixed soon!
