Sat radio and iPod adaptor down again
My Sat radio and iPod adaptor are down again. I was using the sat radio, changing from preset 1 to preset 3, and I got static intermittently interrupting the radio. I then tried to change back to preset 1 to see whether it was the channel, and then it cut out completely. Then I tried the iPod adaptor and that is down too. Only the DVD player and other stock audio features are working.
On the iPod and Sat Radio the interfaces come up, but no sound.
1) Any thoughts what the problem might be?
2) Also how long is the warranty? The iPod Adaptor is Vaistech SL2i-UP, and the sat radio is the Lexus one but dealer fitted. Both installed when I bought the car in May 2009.
exclusive matchup
1) umm, another conflict?! i remember this happened once before? shutting off the car and restarting didn't do the trick i guess? hard to say what happened, wonder if one of the units went wild. but if it's the factory xm radio and the sl2i-up for lexus, they should be accessing two separate harnesses...
2) sl2i-up is one year i believe. factory, also one year at most iirc. personally i don't think it's unit problem, sounds like conflicts to me?
I'll call the dealer. See if they can fix it for free. Otherwise I'm going to an aftermarket shop and will have them either remove or re-wire the GPS system in addition to fixing the problem. if the Vaistech has indeed blown. I may replace it with a DICE Mediabridge since that provides bluetooth A2DP for audio.
inecstaz
10-05-07 08:05 PM
