Help On Cd Changer Question
I just got a new cartridge for my Lexus which I bought without one........I put some cd's in the Pioneer FM35 changer and the remote seems to be workin fine.......now my question is where is the button on the dashboard that let's u switch over to the CD Changer......I can't find it.......there's a tape deck, FM1, FM2, and AM.........where is the button for the CD PLayer?
Did the car come with a factory changer or did you add one? It sounds like your factory HU doesn't control a CD changer if you don't have a CD button on it.
If you added a factory changer, you're options are probably to find a HU from a car that was equipped with a changer, or hope you can get a FM modulator for the changer. FM modulation makes the changer come through a radio frequency, less than ideal but it works. If you pursue this option, check with Pioneer to see if there is something that would work with the changer you've got.
Just re-read your post, do you have an FM modulated changer with a little controller that you mount somewhere? If so, look for the radio frequency that it's sending out. Hopefully the install isn't more complicated than that, like setting a frequency or something. (I've never installed a changer with the FM mod.)
If you're still having trouble, I'd try to call or e-mail Pioneer tech support and describe your problem.
Yes man you are right........I talked to my friend about it and he said it was the radio.......shortly after that I found the station........89.1 which plays the CD Changer.......I was thinking it was AM for some reason........but thanks for the help.....I appreciate it
