Head unit integration
I have a '00 gs 400. In process of removing stock system, replacing with pioneer p9 headunit and zapco remote monitoring system for Zapco 9.0 amplifier. Each piece in dash is single din Problem - due to funky shape of head and proprietary color and finish to area immediately surrounding head, I am concerned about the aesthetics. Has anyone done it, got pics? any suggestions?
BTW - System is Pioneer P9 deck, digital changer and processor; 2 Zapco 4.0's, 1 9.0; Focal Utopia 3 way & 2 12" ID MAX subs. Full active setup.
Thanks for the advice
Ira could you clarify? It sounds like you're asking for pictures of a car with 2 single din units installed? Any pics or description of the Zapco system, im not familiar with it.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Also, what kind of enclosure are those MAXs going in? I have a pair sitting in the garage, I cant decide what amp to use:eek:
If someone had pics of what they did just to make an aftermarket headunit integrate in the GS would be terrific. I am most concerned with making the new headunit surround appear as if it came from the factory - matching texture and color of materials to surrounding ashtray and HVAC areas. Otherwise, I may just have a custom wood kit made to encompass the HVAC, AShtray and Headunit - all from birds eye maple
Zapco piece is almost DIN sized - it is a remote status display that permits monitoring of the Class D amp (9.0) and dashboard control of rail voltage and gain - kind of a remote amplifier control system.
Due to the backlog at ID - if my IDMAX don't show up, I am using DLS. Nonetheless, subs will fire through rear deck - sealed enclosure, re-built (ok custom built) rear deck, subs sealed in trunk but fire directly into passenger compartment through rear deck, flush mounted with it.
Going into the IASCA street class 601 +
As for your amp to the ID MAXs - here are my choices for musical playback, in no particular order. Zapco 9.0, Zapco 6.0 (I am corporate counsel to Sounds Impossible, my installers, would give you a good deal), DLS Class D - if you want this amp, local rep is my client (I am corporate counsel), call me 732 266 1169, Memphis Class D, & Big JL amp all should have more than enough power to move those woofers.
Ira, no wonder I couldn't understand your first post, you're an attorney! JK I dont have time to look for pics right now, but if you do a search in the GS photo gallery you will see what some others have done. What makes it even harder is that the AC and HU are different material/shade then the rest of the car. If you have the resources to fabricate a new face for that whole section that would definately be best, but you already know that. Also, what if you had a cover done that just covered it up like some car manufacturers do with their navigation?
Thanks for the sub/amp info. I'd love one of those Zapcos, but they would blow my budget. I dont plan to compete or show that often, so they'd also be overkill. Im not familiar with DLS, do they have a website?
Moderator - Electronics Forum
[QUOTE]Originally posted by Ira Senoff
[B]If someone had pics of what they did just to make an aftermarket headunit integrate in the GS would be terrific. I am most concerned with making the new headunit surround appear as if it came from the factory - matching texture and color of materials to surrounding ashtray and HVAC areas. Otherwise, I may just have a custom wood kit made to encompass the HVAC, AShtray and Headunit - all from birds eye maple
***How good are you at working with veneer? Also, Birds Eye comes at a premium, especially the veneer flitches "peppered" with birds eyes.***
Percy
Percy
http://www.sounddomain.com/member_p...xus%20GS-Series
Guys, thanks for the link. That is exactly what I was looking for. I hope that the paint and texture can be done as a perfect match, otherwise it is veneer time.
Percy - friend of mine (Phil) found a veneer guy. Not cheap but his work is perfect. For instance - if you have ever seen a Blue MB 560 SEC in the mags owned by Phil Petracca, he re-did all the wood in the car, also custom faceplate, trim rings etc. Bill came to almost a grand but it was flawless. I would pay for flawless work.....
Percy
movaaa55
03-11-09 03:57 AM
lykdatyall
GS - 1st Gen (1993-1997)
07-19-07 10:57 PM
JohnnyBlaze
05-31-02 09:36 AM
