Need Help ASAP! Location of Vehicle Speed Sensor
Help! I'm installing an Alpine IVA-C801 and the Navigation System (NVE-N852A) in a 2000 GS400 (Pioneer system). I need to locate the following wires to connect to the system: vehicle speed sensor, park brake light sensor, reverse light sensor, brake light sensor.
So far this is what I've been able to figure out by doing a search on ClubLexus:
VSS - red/white wire located left of the steering column.
Brake Wire - green/white wire in driver's kick panel.
Reverse Wire - connect directly to reverse lights in drunk
Park Brake - will bypass by connecting a toggle switch to the chasis for a grounding point.
Please let me know if the above is correct. If not, please me know the wire color and location where it can be found.
Thanks,
Michael
Thanks,
Michael
Installation success! Alpine In-Dach LCD and Nav. System. Works great!
For anyone who is doing a similar install, here's the definitive location of the '00 GS400 vehicle speed sensor wire. It is a Violet wire with a white stripe located in a blue color 6 pin plug underneath the driver's dash to the left of the steering colomn.
bklynboi
03-25-10 08:53 PM
