ML + MS-8... anyone?
I just installed the MS8 and it's freakn awesome... just a little frustration at the beginning. but after getting around it...it's a couple of minutes or less to retune when adding and removing components. You have to retune because the ms8 measure the speaker output to do it's thing. I'm currently running 5.1 and will move up to 7.1
I bet 7.1 will kick *** with logic7 and having the signal split among those speakers. I recommend a full range center channel... 3.5" and above because this is where the voice and other goody sound comes from. In fact, I'm going to try to fit a 3 way component for the center and let the MS8 recalculate and balance.
it's magic!
any system will benefit because the ms8 will evaluate the output during scanning phase.
it's magic!
I'm curious which ML Lexus's you guys are installing successfully. I've heard that some people might be having problems with active noise cancellation in the 2009+ ML IS250s. Anybody installed it in an ML LS460 yet?
Also, does the OEM bluetooth hands-free still work properly after installing the MS8? Without echos heard in the car or on the other end?
any more updates on install of this u guys?
i got an mtx req in my gs and i love it. i got it for 100 bucks and it gives me pretty good aftermarket quality sound, however im looking for even better sound so im wondering how good this ms8 actually is and if its worth the extra money?
I'll never do a factory integration without one again.
I'm bumping this up again as I'm currently doing the install in my RX350 ('08) this week.
MrMark or Sam430, do you guys have any info on which color wires to tap at the oem amp? I'll replace the door speakers and tweeters and was thinking of leaving the dash speakers just to see if they add anything to the sound.
You may want to check out AZ IS350 experience with ML and MS-8 at below link. Another link right above his also has ML / MS-8 experience. Its a bit confusing to me why some people are having such a difficult time with ML / MS-8 while others have no problems. Regardless hope all works out.
https://www.clublexus.com/forums/lex...rnal-amps.html (see AZ IS350 response)
http://www.diymobileaudio.com/forum/...some-help.html (another ML / MS-8 experience)
Does anyone know where this can be had outside of the $799 MSRP and NOT fleabay?
And has anyone done this on an OEM ML system? I know it's been posted that it's been completed with aftermarket speakers in the OEM locations, but most systems would sound better from the start if you upgrade the factory speakers regardless. I'm simply looking to be the least amount intrusive to the current set up, since I have a 450GSh which has virtually NO trunk space as it stands and don't want to purchase subs or new speakers for that matter either.
Now for other cars that don't have ML, the MS8 would be worth it by itself.
This is sort of missing the point of the MS8 for an ML Lexus...As far as sound quality alone, I doubt the MS8 is going to be hugely better than your stock ML system; they are both made by the same company after all. Even if there is some improvement, it's not worth the time and effort and money to install it -- unless you are improving other aspects of your system.
Currently I have to rip, re-equalize and burn my 5.1 discs to make the system listenable. If I could easily install the MS8 to the existing equipment with a minimum of fuss and get a flat, accurate FR curve, I'd consider it.
I'm not sure I'd agree with that. My 2009 ES ML system has a 5.1 FR curve that seems to be EQ'd more for movie sound tracks than music, including a huge booming hump in the third and fourth octaves (~140Hz to 250Hz) and additional problems in the upper midrange, that can't be tamed with the existing tone controls.
