installed after market stereo /humm thru speakers?
Old 09-27-10, 12:24 PM
snakehead
snakehead's Avatar
Default installed after market stereo /humm thru speakers?
Just installed a pioneer stereo monitor dvd/cd i just plugged in rc jack that came with the wiring harness kit.,I was going to order the metra speaker plug but did not....everything works but when the volume is turned down there is a humm thru the speakers now...,????
Old 09-27-10, 12:35 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Where is it grounded to?
Old 09-27-10, 01:41 PM
SChema
SChema's Avatar
Does the noise fluctuate or get louder the faster the engine RPMs go?
Old 09-27-10, 01:58 PM
chelli
chelli's Avatar
probably the ground wire... had similar issues before. Check all the ground wires related to what you put in would be a good bet.
Old 09-27-10, 02:14 PM
snakehead
snakehead's Avatar
Yeah i hooked it up to the stock harness ground. I started the engine and i have the whine thru the speakers....Do i have to hook up a external ground to make this go away???
Old 09-27-10, 02:36 PM
MattStarr
MattStarr's Avatar
First of all, yes its a bad ground. To fix it, run your own ground. Just get a self taping screw, 6" of 16 ga. wire and ground it to somewhere metal.
Old 09-27-10, 03:30 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
My SC makes a humming sound and it gets louder the higher my RPM's go. It sounds like I have a turbo sometimes.
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Talking
Does your SC do that too?
Old 09-27-10, 06:39 PM
SChema
SChema's Avatar
No, you either have a bad ground or ran a power cable too close to the RCA cable. The noise is electrical interference coming from the alternator speeding up as engine speed rises.
Old 09-27-10, 08:31 PM
GS FONZy
GS FONZy's Avatar
I had the same issue even with an extra ground, it did help, but still had some noise. I ended up having to use loop isolaters to get rid of the noise.
Old 09-27-10, 08:56 PM
snakehead
snakehead's Avatar
What are loop isolaters? Where do they go and where do i get them?? I can't deal with the noise....Thanks,
Old 09-27-10, 09:07 PM
Emilio253
Emilio253's Avatar
could this be related to the stock amps? because I made my own ground, but i am still getting alternator noise..
Old 09-27-10, 09:10 PM
SChema
SChema's Avatar
Did you guys run RCA cables on one side of the car and the power cable on the other. General rule of thumb the two cables should be around 12 - 18 inches apart.
Old 09-27-10, 09:40 PM
YeA 2jZ
YeA 2jZ's Avatar
I have that noise so bad in my car I have two amps and a Pioneer double din (pretty old still has a tape deck) But I am sure its a combination of bad ground, wires ran too close together, and crappy install. Gonna have to re-wire my entire system because I got the car like that I rather know whats going on than just doing a trial and error method of fixing it. But funny thing is I have an extra set of floor mats front and rears, when I throw them on top of the amps I get no interferance music sounds crystal clear?????weird?????
Old 09-27-10, 11:29 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Talking
The RCA cable is kind of close to the power cable. I'll take a look at it tomorrow. My shop that installed it couldn't get rid of the sound.
Quick Reply: installed after market stereo /humm thru speakers?
