GPS Antenna Location Help?
For those who have an aftermarket GPS unit, where is the best location for a GPS antenna. The unit being used is the Eclipse AVN726e into an 02 LS430 (non-nav model). I'm going to install the unit but I don't want to place the GPS and Sirius antenna outside the car. Where is a good location for these antenna?
Some suggest placing on top of head unit itself and some have mentioned under the rear deck panel. What works best?
On my '01 ES, there is a steel support beam underneath the dash but right above the location of the headunit. It's a tight little space but I stuck the antenna on there and it's always had high accuracy.
If there is metal above the antenna, will it affect the reception? I was thinking of putting it under/inside the dash behind the unit also, but wasn't sure. I just want to do it right the first time. All the instructions say is to mount where it faces the sky without any obstruction. I don't want it visible due to theft issues.
GoodRevs, thanks for your feedback.
Zombie Slayer
YES! Any metal above the antennae will affect reception. A GPS antennae must have a clear "sight" to the sky. Place it in the far right corner of the dash butting up against the window. Ideally, the best location is on the roof/front windshield line dead center.
Thanks mkorsu.
I was considering mounting the antenna in the rear, on the rear deck behind the subwooder grille (this was my only option if it HAD to be visible). Will the subwoofer affect the signal? Or will the stock AM/FM antenna in the rear also affect the signal? What do you think of this placement as opposed to placement in the front? Also, if it is the rear or the front, does it have to be dead center?
From what I researched, the OEM GPS antenna on select Lexus vehicles are mounted under the dash and away from plain sight. Why do the aftermarket antenna differ when the OEM antenna gets great signal being buried under the dash?
Zombie Slayer
Thanks mkorsu.
GPS antennaes will still recieve a signal if they are under something that is not metal. Metal will block the signal completely.
OEM antennaes work because the manufacturers are willing to sacrifice reception in exchange for a high WAF. (Wife acceptance factor)LOL.
thwang99
09-21-02 05:18 AM
