SC300 aftermarket stereo harness, NO OEM SUB OR OEM AMP
Old 11-15-10, 03:34 AM
laurante
laurante's Avatar
oh and by the way, i don't know why anyone complains about the adapter kits on ebay. mine worked just fine, i just had to take out the circle that holds the speakers and drill my own holes, no biggie.
Old 11-15-10, 03:55 AM
laurante
laurante's Avatar
Laying in bed I just had a thought haha. I could wire it to either the cigarette lighter or the ignition wife on the deck? My power is yellow so the red one? Thoughts?
Old 11-17-10, 09:10 PM
Big Mack
Big Mack's Avatar
Cool
Originally Posted by laurante
BUT, i did have one thing that wasn't connected that i usually connect to other cars i've had this deck in, illumination/orange wire. i have a newer pioneer deck btw, maybe a year old or so. but yeah the deck turns on without it, strange. it's just not connected to anything, i don't know how that works haha.
That works because all it does is dim the radio when it gets a +12V signal.
thanks for all the help so far, big mack, you're the man!
Glad to help, mang.
Which wire are you talking about? The illumination? No need. If you want it dimmed all the time, you could wire it to the switched power, but it's your call.
Big Mack
Old 11-18-10, 12:37 AM
laurante
laurante's Avatar
oh sorry should have specified, the remote wire for my amp.
Old 11-18-10, 10:36 PM
Big Mack
Big Mack's Avatar
Cool
i got around to installing stuff today, went pretty... okay. for some reason the remote wire doesn't work, might be the deck, might be the amp i got (it's used), not sure. but when i connect it to the remote wire on the deck harness it doesn't turn on, but when i connect it to the constant power it turned on fine. any suggestions on other places to wire it to?
Just one.
Originally Posted by Big Mack
...find a wire to tap for the switched power. If your cigarette lighter is off with the key, that's a good place to start.
Hmmm...
As for the amp not turning on, are you sure you're using the remote turn on and not the remote for a power antenna trigger? That will only come on with the AM/FM, not CD. Check your wiring again, but if it's correct according to the manual, you can use the cigarette lighter. I would trigger a relay to minimize the current draw. You can jump the +12V supply for the relay from your supply for the amp. The fuses for the cigarette lighter and for the amp will negate any need for additional fusing, too, so that saves you some hassle.
Big Mack
Old 11-22-10, 10:56 PM
laurante
laurante's Avatar
figured everything out, good to go. thanks again sir!
Old 11-23-10, 06:11 PM
Big Mack
Big Mack's Avatar
Question
Glad to help, but what was the issue? I'm curious if I was right.
Big Mack
Old 11-23-10, 09:34 PM
laurante
laurante's Avatar
the deck kept cutting out too. ended up being... a dead battery. hahahaha. the remote wire was fine. oops ahaha. felt pretty dumb.
now it's time to find some mdf and build a massive box. i hope it'll fit in the trunk.
Old 11-23-10, 09:56 PM
Big Mack
Big Mack's Avatar
Cool
Nice.
For the enclosure, measure the opening, or buy a really BFH and make it fit.
Big Mack
hatteroo
12-16-10 02:32 PM
SC400-PHAE
SC- 1st Gen (1992-2000)
12-13-10 06:07 PM
P Rock
01-05-07 01:04 PM
BruteSBC
04-15-05 04:13 PM
whatuusay1
11-12-04 03:47 PM
Quick Reply: SC300 aftermarket stereo harness, NO OEM SUB OR OEM AMP
