DIY Fail!
I tried to do a DIY install of a VAIS iPod integration unit, but I could not get the air vents off. I think I may have broken a clip or two....ok, maybe three, but I am not sure. Anyway, I plan on taking it into a pro shop so they can do it for me. I hope the fact that I may have broken a clip or two does not make it hard to remove the air vents.
times 2, stuff gets broken at times and thats way they make replacement parts.
If the car is assemble, then it get dissemble in the reverse procedures. NEVER use brut force to dissemble, it is usually the wrong way. I usually stop before using brut force and rethink.
flathead screwdriver + cloth ftw. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
break more, learn more. I started breaking my Honda when I was 16, now I'm pretty good at DIYing. I've broken a crap ton of stuff ranging from corner lights to amplifiers to Gameboys, don't let it stop you. Yesterday I just learned that wet-sanding does not repair brushed aluminum.
theres 4 tabs inside the top of the air vent that need to be pushed down then you can pry the air vent from both sides gently and get the air vent out. dont unlug the two harnesses, just swing it up on top of the dash
Hopefully u dont upgrade to a rolls royce or bently...
royce and bently are really no difference cause there more expensive i have never broken anything in my car or anybody else.. but if this your first time owning or working on any car,,then yea your going to break something...i have work installing music and complete rewiring on numerous car i have work on but common sense and experience goes a long way and the most important part ...is ask if your no sure on something case in point with rrr0005 the air vent clip can break if not pull right by the way on which car are you working on rrr0005 you didnt stated on your post
