Electronic devices and window tint
When choosing window tint, check to see if it is "signal-enabling." I never knew that some tint blocked signals from keyless entry and satellite radio. Lesson learned!
See, it is comments like this that lead to ignorance continuing. Metalized tint affects many signals, and while there are many grades of tint, even expensive metalized films will affect them. Some can be optimized through different processes in the layering, but to say that "cheap tint does that" is not at all accurate.
I'll share this with you to prove the point - a few years ago Mercedes new models came out with a metalized film impregnated between two layers of glass to aid in heat dissipation/resistance. It was very effective at it limiting the heat penetrating the cabin with only one issue - it kept the keyless entry signal from hitting the receiver in the car. They changed positions a couple of times, ending up with it at the base of the windshield, and still needed to cut a small square into the panels before impregnating the glass because it kept the signal out.
Now, think that film is cheap? Try purchasing a genuine Mercedes windshield and you'll quickly find out that it is not at all an inexpensive proposition.
Big Mack
Big Mack
Big Mack
Big Mack
NO i repeat NO Mercedes uses film.
The glass you reffer to is actually a dyed glass you can think of it as a R or U value to keep heat and cold out. Lexus did the same thing with the SUV except with a slight Bronze/Gold hue on the rear windows back.
BTW i recently replaced the windsheild on my s550 this past summer wasnt very expensive ;]
but i will say this if its not a good film like sunguard or something its crap and will affect signal's. so again CHEAP TINT DOES THAT
And yes, they absolutely do use laminated (aka film) glass in their windows and rear windshields. This is a slight tint, and customers can order the privacy glass if they choose (or dealership can make it their standard order). It is not the same as regular window tint, but it is a film, not just a dye. I do see your point in that it is not an external film, however.
Big Mack
2010, automotive tint, back, car, electronic, film, lexus, merallized, mercedes, metalized, metallized, rear, s550, tint, window, window tint, york
