ANYONE heard or know of DLS speakers? Precy, Mean Gene?
I ran across these and they look pretty good.
Anybody have any experience with them?
Which separates look the best?
How bout the specs on the infinite baffle sub?
Thanks in advance.
Ryan
CLICK HERE FOR THEIR SITE.
Thanks in advance.
Ryan
![](http://www.dls.se/speakers/oa10a.jpg)
Here is the info on the sub...
DLS OA10
PRODUCT SPECIFICATIONS
10” CAR SUBWOOFER MODEL OA10
DOUBLE FERRITE MAGNET SYSTEM
PAPER CONE, FOAM SURROUND
DOUBLE SPIDERS
Dimensions:
Diameter 268 mm / 10,55”
Mounting depth 136 mm / 5,35”
Mounting hole diameter 238 mm / 9,37”
Nominal power handling 180 W
Maximum power 360 W
Nominal impedance, Z 4 ohms
Sensitivity, 1 W / 1 m 86,5 dB
Frequency response 25-2000 Hz
Fs, resonant frequency 39,9 Hz
Voice coil diameter 50 mm / 2”
Voice coil height 34 mm / 1,34”
Voice coil wire Copper
Number of layers 4
DC resistance 3,59 ohm
Voice coil inductance, 1 kHz 1,72 mH
Magnet system Ferrite
Magnet weight 80 oz / 2,27 kg
Magnet diameter 145 mm / 5,71”
BL product 11,96
Max. linear excursion, X max +- 9 mm / 0,35”
Suspension compliance, CMS 183
Mechanical Q factor, QMS 3,19
Electrical Q factor, QES 0,55
Total Q factor, QTS 0,47
Moving mass, MMS 86,89 gr
Equivalent Cas Air load, VAS 25,5 liters / 0,6 ft 3
Cone / Dome material Nonpressed paper
SD - Effective piston area 314,6 cm 2
Net weight 5,3 kg / 11,68 lb
Basket Chromed steel
The infinite baffle sub does not work in a 'free air' situation. The Qts is too low. I wonder whether these guys know what they are doing.
I've checked out the specs of free air subs from Dynaudio, Focal, JL and Vifa. They all compute. These don't. Their other products might be OK, but their free air sub won't work.
Stevie
Stevie
Not quite. Free air is something of a misnomer. It is generally understood to refer to a woofer that will function on a rear shelf loaded by the trunk.
In practice it means a woofer that is comfortable working in a sealed volume of 200 - 400 litres. That's not really free air, but it's the way that the term is used.
Stevie
Stevie
Search Function Inc.
Actually free-air means that there is no barrier between front and back waves. If your sub is hanging on a string and you play it, that's free-air. There are no such situations in car audio but many assume that free-air is anything withought a box.
IB is another case. That is where the front of the sub is separated fromt he back of the sub with a baffle. That is our classical rear deck application.
Check my install. That thing is IB.
I think that Infinite baffle and free air have merged into the same in car audio. The reason IMO is that retailers sell subs as "Free air" but as Retro said it is impossible to have a true free air setup in car audio. It seems like it would be easier to sell and describe an infinite baffle setup to beginners as "free air". Maybe thats what creates the misunderstandings?
I have never heard DLS in person, but I have heard good things about them. They are fairly popular in Europe I believe, but I dont think they have been in the states very long.
I didnt look at all the specs on the website, maybe you could narrow it down to which seperates you are interested in? The sub looks like it would do well in SQ, but kind of weak in SPL(Foam w/Paper cone, 9 mm excursion, 360w peak). Another CL member who competes was talking about these, but I forget who, do a search.
Here is a link to a great show-winning car in Europe using DLS speakers, cables, and amps:
http://w1.501.telia.com/~u50103051/eng_index2.html
They also have a US web site: www.dls-america.com
Phil Petracca, an IASCA competitor (and SQ judge, too, I think) is running them in his competition car. A lot of the top IASCA judges say his car sounds amazing. You can find him over on the Carsound.com forum as "PhilthyPhil". I believe he is also a distributor but not sure. Hope this helps.
Bill Bodwell
Bill Bodwell
Well, I have the insider information on this one.
Philthy is a very good friend of mine (10+ years). I also happen to be his attorney for business purposes. He is the rep for DLS. His Mercedes Benz (world champion IASCA 301-600 amateur ultimate) is a Dynaudio/Zapco/Image Dynamics car built by Sounds Impossible (Impossible Bill Acevedo/Omar Buker) (more very good friends of mine). We all met from competing in IASCA back in the early 1990's (well before I became an attorney)
Phil's Jetta is the DLS car - speakers and amplifiers. Last weekend the car got caught in a flash flood and he now needs a periscope to operate the vehicle. He soaked it before I got to hear it but I am sure it sounded very nice from the feedback I got from trusted individuals The car needs a new motor etc and insurance co is rebuilding it. Ths install looked great (especially for a "street" car)
As for DLS - Phil's got the scoop. My GS is going in this weekend for full install - Pioneer P9, Zapco amplifiers, DLS speakers and Image Dynamic subs, when I get the car back in a couple of weeks, I'll let you know how it worked out.
If you need info on DLS, call 732 291 8808 Sounds Impossible or 908 624 1992 Phil's rep firm.
GO TO SITE
www.dls-america.com
Phil says call him if you want to talk with him (732) 778 5184
Stevie - as Phil is reading your post, he is laughing into the telephone receiver as I type. IB(infinite baffle) is freeair. Phil says call him for tutorial.
www.dls-america.com
Kohinoor
03-23-09 01:38 PM
Tymboo
09-09-06 10:28 AM
Alexus-Kia
08-11-05 08:57 AM
