vss wire location
The wire you're looking for is purple/white. It's in the driver kick panel at a module called the "Power Steering ECU", right in the middle of the driver kick panel and the ABS module.
i know there is an input for one, but I don't think you're required to wire up the VSS on pioneer units. it should tell you speed based off the nav antenna. have you tried using the unit without the wire hooked up?
orion603
05-28-18 03:16 PM
