Vaistech ML Plus (ML+) Review - Buy Recommendation from former SL2i user!!!
#241
My friend is installing the ML+ in my car and he's a tech -- he's pretty sure he's got the wiring all down right -- anyone have trouble having the screen show the VAIStech menu? It's still on the nav screen for me after the left button thingy
#245
hi all,
new to this forum and thank you for all your support, answers, advice and contributions. hope i can do the same.
i have couple of questions :
1. is ML+ compatible with 2008 LS 460 backup camera? i heard that there are issues...
2. do we need nav override such as PS to watch video playing from ios 4 device through ML+ while driving?
3. do we need nav override to browse through song/play list while driving?
thank you in advance and you guys are awesome!!!!
#246
hi all,
2) no, with ml+ you can enter a code every time you start the car and that will enable video
3) if you are using the graphical mode, you don't need override. if you go into the mp3 emulation mode (or for example with non ios4 devices), then the menus will be grayed out and you will need override in order to do so
#247
About to pull the trigger on a ML+ then I see this. I have a 2009 GS450h with Mark Levinson/Nav/BackUp Cam. If I purchase an ML+ will I be able to use all functions (MP3 Emulation as well as Graphical Interface) without any further troubles? As well, will it take full advantage of my Mark Levinson system?
#248
1) if you have mark levinson audio, i don't think it's compatible yet. i have been waiting
thank you very much for your reply.
i do not have mark levinson, but i have nav and backup camera.
so ml+ will work with my backup camera, right?
#249
if you do not have mark levinson, i believe that will work. but you should double check with vaistech, because some other options like auto-park might affect things (ls460 is just too complicated)
#250
gs450h is totally fine. ml+ has problem with ls460 with mark levinson (last i checked). on the GS and IS, it works 100%
#254
Do you know when would the ML+ be finally available for the 2010 Model ES350 with backup camera and without the Levinson system.
And it's OK to let us know the actual, realistic date, time frame rather than keep saying next month, now for the the last four months or so.
Thanks You....
Thanks You....
#255
Club Lexus Vendor
Thanks You....
Thanks You....
