Vaistech ML Plus (ML+) Review - Buy Recommendation from former SL2i user!!!
#31
Volume setting greyed out in iPod out mode
Batman75,
In your video review, you talk about the Source Settings screen where you can change various settings such as Brightness, Contrast, Saturation, etc. One of the adjustable settings on that submenu is Volume. Because the regular radio volume is quite a bit louder than the default volume of the iPod out and iPod video out, you pointed out that
the Volume control settings of that ML+ submenu can be used to increase the volume of both iPod out and iPod video out to equalize it to match the "loudness" of the radio settings, so that when you cycled through the media modes (AM, FM1, FM2, CD2/MP3 emulation)--they would all have the same volume. Otherwise, if you used the radio's volume control **** to raise the iPod out and iPod video out volumes to a loud level, when you next cycled through to the radio modes (FM, AM)--the volume on those modes would about blast your ears off. Like you indicated, in iPod video out mode, I was able to increase the Volume in the Source Settings submenu to +9, to where it closely matches the loudness of the radio. But here's the rub: that same Volume setting is greyed out, to where i can neither increase or decrease it when I'm in iPod out mode. Can you check your iPod out, and verify that you can indeed increase the volume from there?
#32
Batman75,
But on my system when I am using iPod out, the default volume level is louder than on my sat radio and cd player at the same amp volume level. That's the opposite of your default setting.
I wonder if it is grayed out because the default volume is set by the ipod itself. Try setting your ipod to max volume and re-connecting it.
I will also check with Vaistech on this.
#34
This is interesting. The audio level adjustment is grayed out on my unit also when in iPod out mode. But on my system when I am using iPod out, the default volume level is louder than on my sat radio and cd player at the same amp volume level. That's the opposite of your default setting. I wonder if it is grayed out because the default volume is set by the ipod itself. Try setting your ipod to max volume and re-connecting it. I will also check with Vaistech on this.
I wonder if the reason YOUR iPod out sounds much louder than mine is because you have a Mark Levinson stereo system, which benefits much more from the ML+'s digital sound setup than my non-Mark Levinson stereo?*
I certainly appreciate your offer to check with Vaistech to see what's going on with the greyed out Volume setting. It is especially puzzling because the rest of the buttons on that submenu work perfectly, as designed. It's a mystery!
#35
I had already tried adjusting the iPhone's iPod volume. It was already at maximum volume (and my music level through iPod out is indeed quite a bit lower than the native radio volume). Then, I tried setting the iPhone's iPod volume level at mid-range (disconnecting and reconnecting iPhone to apply the new setting to the ML+ system), to see if that would "un-grey" ML+'s iPod out volume setting. Still greyed-out. One thing that DID help quite a bit with the loudness in general, both when I played music straight from my iPhone's iPod, and when I played music through the ML+ iPod interface, was turning my iPhone's iPod settings (via Settings / iPod / Sound Check) to "OFF". After applying this partial fix, I again disconnected / reconnected my iPhone, then checked to see if iPod out Volume was still greyed out. It was. At least, with Sound Check off on my iPhone, the volume level of iPod out is closer to radio volume level. I currently have my ML+ iPod video out volume set to +9, so now when I cycle through radio, iPod out, iPod video out, they are all much closer in volume. Another setting I experimented with on my iPhone's iPod (via Settings / iPod) is the EQ (equalizer) setting (I tried Rock, Acoustic; finally left it set to "OFF"). No EQ changes had any effect whatsoever on the volume level of my iPod out via the ML+ system. FYI, in case you are wondering, on my iPhone's Settings / iPod screen, I have the Volume Limit set to "OFF"; I didn't make any change to this setting at any time in the experimentation process.)
1. iPhone/iPod volume has nothing to do with "line out" or "USB Audio" outputs. It is only works for your headphones or bluetooth audio.
2. Do not compare volume of AM radio to other sources. It is always louder than other sources on most Toyota and Lexus vehicles.
3. I do not recommend you to use "Sound Check" functionality (turn it OFF and keep it this way) on your iPod/iPhone, unless you want to get additional distortions. This technology same as ASL. Dynamic volume adjustment can not give you quality sound. Same thing about EQ. EQ settings on your iPod/iPhone designed for your headphones, not for Lexus or Toyota amplifier. They have own EQ controls...
4. "iPod Out" on ML+ is digital output, and NOT analog. First play with "Volume Adjustment" in your iTune or if you are using USB Flash playback use MP3 gain adjustment software (read VML/ML+ manual). Most digital files have own volume/gain settings. This is a only correct way to make your "volume setting" right!
5. You can not compare two audio sources, unless you are playing exactly same song (same volume, same digital gain settings, and etc.).
#36
Any clue if the SL2iC is the same (meaning it resorts to emulation mode) if a non-iOS4 iPod is plugged in?
I really want the BT/NAV unlock function from the SL2iC. The ML+ is great for what it is if you want USB access, but I'm not really concerned with extreme fidelity (lossless MP3s played via digital interface) in a car. Cars are horrible for sound-staging to begin with, and the difference is marginal. If the SL2iC will play non-iOS4 iPods, then I will pick up the SL2iC so that I am future-proofed against an upgraded iPod w/ iOS4.
#38
Regarding the sound fidelity, I am not an audiophile. My home stereo consists of a Sony ES amp with Bose 901s front and 301s rear.
But the difference vs. the analog SL2i-UP on a Mark Levinson system is black and white.
#39
You have to ask rominl this question since I don't have Sl2ic.
#40
I suspect this is the case. In our ES350 which is also non-ML, I also don't see much difference between listening to a CD and listening to the SL2i-UP. I've only noticed a substantial difference in the GS460.
#41
Club Lexus Vendor
This is interesting. The audio level adjustment is grayed out on my unit also when in iPod out mode. See below.
#42
exclusive matchup
i think it's about time to invest in a little itouch with ios4
#43
exclusive matchup
2) Buttons vs. touch and swipe anywhere on the screen. When I first turned it on, I was thinking of my iPad and tried to touch playlists to select playlists. That didn't work, so I had to use the arrows on the right to select the line and then press select. Same thing with scrolling - you have to use arrows and can't swipe. These are probably limitations of the Lexus capacitive touch screen so not sure Vaistech could do anything about this anyway - but it would be better.
3) Lack of menu for iPod video out. You have to select videos using the Ipod screen rather than browse the videos on the ML screen. This is actually annoying. I think it would be great if they had a way to browse your music videos on the screen. Better yet just add music videos to the iPod Audio qout interface and have the system toggle the modes automatically.
2) The limitation has more to do with Apple, because they don't allow any direct touch control with the new iPod Out feature. It's more of a "display" and it allows simple commands like up/down/left/right/repeat/shuffle. So that's why Vaistech's option would be to use utilize these controls and send those commands to the iPod.
3) This is another limitation from Apple. Probably because of safety, again they don't allow video out. So Vaistech had to find a way to get around the system. That's why currently there is no way to allow selections and control of iPod video directly on the touch screen, and have to go through the iPod itself. Apple also disabled the video section from the playlists, artists, albums, etc... screen, so only way to do it is manual
#44
To touch a few points that i was able to discuss with Vaistech about:
