Vaistech ML Plus (ML+) Review - Buy Recommendation from former SL2i user!!!
#76
In the GS460 ML system it is certainly not placebo. It is a stark difference.
#77
I should add, I do like this device. It's one of the better devices I've used. If someone asked me to rate it, I'd probably give it 3.5 / 5 stars.
#78
When I first got my SL2i-UP I did a back to back comparison of the same tracks on CD and Sl2i-UP and found the SL2i-UP output to be noticeably inferior. I did the same with the new setup and found them to be on par.
However, I would ask that if anyone performs this test themselves they use a lossless format. I keep hearing a lot about lossless MP3's, but I haven't seen too many people that have actually transferred lossless MP3's to their iPod ;-). I would highly recommend going directly from DVD/CD to Apple lossless or FLAC (and then convert to apple lossless). Just my 2 cents.
#79
My cable was from Bestbuy, so I can't speak to the VaisTech cable. If you do some research on the latest apple devices and their latest cables you'll find out a little more about device compatibility with cables, DRM chips, and the video tax. I'll just say I tried 2 non-apple cables that were supposed to work find with my device, and they both sucked, so I ended up reading a lot about the latest apple devices and cables. Having said that, the VaisTech cable might be fine.
#80
However, that's not really the case with Apple. I guess my URL's aren't coming through. Just go to ilounge.com, click reviews, and look at the cable reviews. Make note of how you need a cable with "Apple device authentication chip inside" (in many cases) for full audio and video functionality.
As far as Vaistech's cable being an issue...I don't know because I didn't buy it. I would think Vaistech tested with their own cable, but having said that...I don't know that for sure.
I did have some fuzzy-ness (horizontal interference) prior to switching to the Apple cable ($39 @ the Apple store)...however I also switched a couple of other things at the same time I installed the new cable. I re-encoded the movie and changed how my cables were routed, so I can't say definitively that specific issue was related to the cable.
Sorry, I wish I could be of more help. All I could say is it might be worth a try (if you wish to expend the resources).
#83
If I remember correctly, I had horizontal interference on both the iPod Out and iPod Video out, but only when it was actually getting a feed from the iPod touch (not prior to it getting plugged in). It was just way more noticeable/annoying on the video feed.
If you wanted, you could hit the apple store, buy the cable, and just test it directly from the ML+ prior to routing it to where ever your mount is located, and see if that resolves your issue. It may not fix your issue, but based on what you are telling me it sounds like it's definitely worth a shot. What generation/model iPod do you have? Just an FYI: Mine is the 32GB Ipod touch 4th generation; I purchased it this past weekend.
#85
I upped the contrast and brightness to the default values, which really makes the black levels crappy, but is probably appropriate in the sun...and well I'm still seeing some horizontal interference. I do believe it's loads better than my other cable (but that could be psychological), and bottom line...unfortunately the horizontal interference is still there...and will probably drive me crazy.
I may try re-grounding the device...but I can't say I'm convinced this is the root cause.
I also tested the "back" button on the steering wheel while on all songs with *no* shuffle, and it skipped ahead a song every time I hit it. /sigh
Did I say I give this system a 3.5/5 star review? I might mean 2. The sound is nice, but the back button not working on the steering wheel, and the horizontal interference with the display (when the screen is at the default values) are issues that should be solved in beta imho.
#87
Maybe you have another noise source in your car.
In my car for example when battery not fully charged and cold outside backup camera produce terrible diagonal interference.
Yes it is a bug!
#88
This is actually not a ML+ glitch. It is normal Lexus behavior. You can disconnect ML+ with Camera active as a last source and you will still have camera ON (figured out this during my installation)... Just push "MAP" to change default source and next time you drive you will get MAP on your screen instead of Camera.
#89
I do not think black level on "iPod Out" and "iPod Video Out" the same. To me "iPod Out" looks brighter. I do not think it is done this way by VAIS. When you adjusting brightness and contrast of video signal you can boost artifacts and noise dramatically. Did you check brightness and contrast adjustments on your display (Lexus settings)? Is your iPod fully discharged or close to this? Try to turned off iPod and see if it's make any difference. If so, maybe source of this noise iPod itself (LCD backlight for example).
The investigation will continue this weekend.
#90
I ran into another glitch this morning, I couldn't disengage shuffle. I would just keep pressing the shuffle button and nothing would happen (the shuffle icon remained in the upper right of the screen). I tried holding it and still nothing. It only went away when I turned my car off and back on.
I agree 100%. It honestly feels like I'm Beta testing. I mean really? The back button on the steering wheel doesn't work? I made sure on my drive to work this morning, and it doesn't work regardless of shuffle settings, whether you're in Playlists, Albums, Songs, etc.
I was wondering that too, but having a second person with the same problem is beyond coincidence I think.
I never changed my settings, but I can try playing with it later. The problem is of course that I have my screen settings the way I want, I shouldn't have to make the screen brighter or dimmer as a workaround.
I'll try this as well, but again, this is something VaisTech should have figured out during Beta testing.
I wonder if there's any useful info in this TSIB for 2IS owners: https://www.clublexus.com/forums/is-...-released.html
When I put my car in reverse and the backup camera turns on, that's normal Lexus behavior. When I shift into Drive and it's still on, that's a glitch. Thankfully, it hasn't happened to me in the last couple of days.
