Do I need to upgrade my alternator?
I need some advice.
I have an 02 gs430 with stock navi. I installed a rf3sixty.2 along with all dynaudio speakers, 3 amps. PPI pcx-2200 (200X2rms) for fronts, PPI pcx-280 (80X2rms), and a PPI pcx-2125 for sub (500x1rms). There's also a cap in the car.
My problem is and has been for a few years now. If i listen to my music loud, or turn up the bass and I am stopped at a light, my navi will turn off and the battery light will show up on my dash board. Goes away if I give it a little gas. Also if I use A/C or anything else electrical it will do the same. I have switched the stock battery for one from costco. Does the same thing. My car will always start so it never completely drains the battery.
I know this must be overworking my stock alternator, but it does continue to work. Also would doing the big 3 solve this issue, or do I just need an upgraded alternator. Or possibly a deep cycle battery. (I am looking for the most economical alternative)
I also have a few tv's in the headrests but they are not wired up.....yet.
Thanks in Advance
Thanks in Advance
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
If it is only doing it at stoplights, you are overwhelming the stock charging system - but just barely. I would highly recommend going the big three to start, see if it alleviates the problem. Bigger battery won't help. All batteries do is store a charge. If upgrading the wires doesn't do enough to stop it, it's time to upgrade the charging system.
Question, though...why didn't you upgrade the negative cables when you installed the gear? This is a common issue that many who install more electronics in their cars see, so I'm curious why shops aren't really requiring it from the start (if you went to a shop).
Big Mack
Big Mack
Big Mack
Big Mack
Also I did the install myself. I have thick wiring (i think it was 0 gauge) for the power to the amps and the ground for the amps, but I never upgraded any other wiring on the car. Any recommendation on what gauge wire I should use for the big 3. Also I'm guessing I should just get my own cable instead of buying a grounding kit, right?
Yes. Right here:
Now, about this:
Probably should remember to always do that.
Yes. Don't overpay for someone crimping on the terminals. Just buy the same size wires for each, crimp on some quality connectors, secure them properly, and move forward.
Big Mack
Big Mack
If you are running that many watts then I think that the big 3 is a good start but a stock alternator does about 90 amps. The car itself uses roughly 60-70 amps if I am not mistaken. I upgraded my alternator to a 200 amp and also put a 1900 cold cranking battery in the back that runs the stereo system. Make sure you have good grounds to the chassie and that each amp is independently grounded. You should use at least 4 gauge if not bigger. Also make sure you are putting the grounds on bare metal. Make sure you use the same gauge ground and power wire.
Hope it all works out for you!
Sounds like there's something else going on there. I don't think that those 3 amps alone will do this to the electrical system.
Big, what do you think? I know many people who have not done the big 3 with no issues with the stereo/electrical system. Just seems like there's something else causing the problem.
Do you have the amp gains turned up all the way?
I have found a company that sells 200amp alterrnators for 200bux. Doesn't seem bad, but how about if I do the big 3 and put a smaller pulley on my stock alternator? Any suggestions?
Also my gains are all 1/4-1/2 up.
I do think that the amps can do this since it's only at idle. Assuming he's using 50% of the power and those amps are 80% efficient, he's drawing down about 50A. He said the problem vacates when he's moving, which lends me to believe that it's barely overcoming the alternator that is not spinning as fast. He's done the test I would, which is eliminating the load he thinks is causing the problem, and it's all working well save for another load being presented (A/C).
LA, I would still do the big 3 to start. You don't want to spin the alt any faster on the stock brushes, as it will give you very little gain and will certainly shorten the life it has remaining. I wouldn't buy the other alt just yet. Do the upgrade, check all your connections at that point (positive and negative), and rediagnose. If the problem persists, it may be time to upgrade.
The unfortunate fact is that these cars have a TON of power accessories and not a lot of extra current on tap. Just out of curiosity, where did you find a 200A alt for $200? I just did a sweet (AKA: cheap) upgrade in my DD. It uses the same alt as a truck, and it bolts right in, so I grabbed one for $78 and gave myself an extra 50A.
Patience, mang! We all have to sleep sometime.
Big Mack
Thanks Again BigMack. I will be doing the big 3 upgrade and I'm ordering some 0 gauge wire asap. I will also look into some good terminals for the wire.
The 200amp alternator is an ebay alternator but the shop is local to me. 2 miles away. http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
Not sure how reliable these are but there are plenty of 200amp alternators on ebay for less than 200.00
That alternator is for a 400, not a 430. If they have one for a 430, though, seems fair. I'd definitely look there since they are local to you.
Big Mack
You can find good terminals on ebay or your local audio shop. They may, if you buy from them, even crimp them on for you if you know the proper lengths since large crimp on connectors can be somewhat difficult to do.
Big Mack
Big Mack
Thats why I was asking in this thread about adding a smaller pulley to the stock alternator.
Anyway I will update once I get my big 3 finished.
