Static noise on aftermarket unit
I just finished installing my JVC double din and every time I turn on the radio I get a static/buzzing noise, it gets worse when I turn the key to acc or when engine is running. I using Metra wiring harness to connect to the stock harness. Could the issue be bad grounding and I should run my own ground wire from the aftermarket radio? Any easy fix?
This is on 98 SC300.
bunthy
07-13-08 07:35 PM
