PICS: Final touches to system
Hey guys, well I finally got off my lazy butt and finished the touch-up part of my system. The touch-up included new PG Battery clamps in a "black chrome", a PG circuit breaker, and a fuse holder.
BTW: If you haven't seen my system yet, click on the link in my sig and scroll through the pics.. Thanks
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
LX - Nice install!!
Here's a possible trouble-preventing idea for ya. I had a 150 amp Phoenix Gold circuit breaker on my S-10 & although they R generally trouble free, I had mine freeze up ( in the closed position, no less!!:eek: ) after about a year of being under the hood. Fortunately the downstream fuse system did it's job & I suffered no major damage but i'd suggest that u trip the breaker every few months of so to make sure that it doesn't do the same thing to you. I'd hate to see a sweet sytem like yours suffer a meltdown!!:eek:
Originally posted by LexusRules
very cool but u have TEIN right? how do u adjust stiffness with that cover?
Gene: Thanks for the heads up. Man, I didn't even think of that. I'm glad nothing serious happened to your old system. I probably will trip the breaker every 2 months or so... Thanks again.
Looks good. I also had a circuit breaker get stuck on my first install. They are convenient, but regular fuses tend to be more reliable. You probably wont have any problems, but hopefully everything has built in fuses just in case.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Eng - The capacitor just stores energy ( in farads ) for use by the amp. It won't hurt anything to trip the breaker as long as the system's not powered up ( especially if the cap's already charged ). The breaker/fuse setup on the power wire is a safety measure to guard against electrical problems downstream of the battery ( like an amp grounding out ). The breaker will be overloaded beyond it's amperage rating & will trip. The cap's just along for the ride. However, I'd exercise caution when charging a discharged cap back up to full power. I've seen more than one explode when suddenly hit with a full 14 VDC. Most cap companies include a resistor with their caps to slowly charge the cap up ( takes less than a minute generally ). U can also do the same thing by using a battery charger with an adjustable output feature. Just hook up the cap & slowly increase the voltage/charge coming from the charger. Just periodically trip the breaker with the system off & verify that it trips & resets so that if U DO need it, it'll function as designed. Personally, I'm with Sirs - I like to use Maxi-Fuses because I can see that those have melted just by looking thru the waterproof cover.
happy_es3
03-07-08 08:51 PM
