98+ ECU replacement
98+ ECU replacement
hey guys,
i have diagnosed my power drain problem down to a bad ECU.
before i buy a used ECU (i found one with the same OE # as my current one) i want to make sure i can go through the program procedure to make sure the car will start.
i know of the procedure to program the transponder if you get a new KEY, but what if you get a new ECU?
