Upgrade Mark Levinson thru summing external amps
You can still use the HU or steering wheel volume controls. If you use the volume control on the Bit One DRC, you have a few more options available, such as dynamic eq control, sub level control, tuning presets, etc. But for volume I use both about equally.
@ AZ IS350 thanks for the heads up on the LCQ-1.. i just ordered 2.. not a big fan of eq's but it may help alot in flattening out the RTA a lil.. an the sub control will be a plus (big step up from LC-6's originally planned on using)
Update..cant get the LCQ1 to work properly with the ML amp it (ML AMP) requires a resistive load to provide proper output and the LCQ1 cant do this..i have tried multiple resistors an no luck..going to sell them.. an start again for now i have 6 SNI35 ($9) hi/lo convertors which work fine but there is horrible system noise at zero volume.. anyone try the rockford 360.3 on an ML amp?
fatalexx
06-07-17 08:14 AM
2007, 350, amplifier, disappointed, gs, jbl, levinson, lexus, ls460l, mark, mark levinson, mark levinson amp replace, ms8, speakers, upgrade
