Urgent : Help - No Audio
I've HS250h Premium with Lexus Premium Audio - it comes with a multi function display monitor.
I was playing music from my iPod - took it out and then next time I tried to turn radio on there's no sound. Here're couple of strange observations :
- No sound from any source - not from radio, CD, Aux, Bluetooth - not even from voice command or navigation.
- Pressing the vol control **** does show Audio Off or when turned on it does show radio station or CD/iPod track but no sound.
- Turning volume control doesn't show anything on the monitor display - normally I'd see a number for volume from 1 to 65. Looks like unit is aware that volume control is not working.
check radio ;and factory amp fuse'and if they but have power ;; then take of battery grond for a few minutes and the put it back and see if radio come back on;;;
if after doing all that and still dont work and radio have power and no sound factory need replace or you use and after market four channel amp'''
hey man seem as if your system need to reset here is wht i want you to try '' the the ground side of the battery off for about 5min the put it on back your system should starting playing again ;if this become continuos there is a problem with the factory amp;; let me ;;;know if it work;;;
Thanks for your suggestions.
